I don't think you can, actually, unless you have the capability to reprogram them.The RFID can be side stepped by respooling new filaments onto Bambu spools. I had almost bought the X1C but went to Prusa.
but for once I'm thankful for the paralysis by analysis that cuased me not to pull the trigger yet on the X1 purchase
I've never bothered to try to reuse the rfid tags. New spools or refills come with new tags. Other filament providers don't use tags and they work just fine. Bambu has some presets for numerous other manufacturers. Just tell it what you're using and it works just fine. If the manufacturer isn't listed you can just pick generic filament and, again, it works just fine. I thought that the rfid tags also kept track of how much filament was left on the spool but I could be wrong about that.No need to reprogram, just replace with like for like. Respool other make of PETG onto a Bambu PETG spool for example.
So far as I understand it, if you use LAN printing you can’t use the camera in the app.I have held off on 3D printing as well because I was waiting for a more user friendly design that I didn't have to fiddle with to get it going, or adjust as often as some types seem to need. But I worry about what else is around the corner with this now and that if I did really get into it and wanted to fiddle that I would be able too. Sounds like if this firmware change stays I would need to get a second printer for trying different software, and I don't want to have to do that. Can you use a different slicer (ie. orca) and put it on the microSD card to take it to the printer? Can you use the camera if you initialize the print from the MicroSD? So much I don't know about 3D printing.
If it went completely sideways I’d be putting a new board in and running Klipper.There are lots of crafty bastards that will circumvent this, and I suspect it will happen so fast it will surprise us all.
That is some straight-up doublespeak. You only get to play with their permission.Bambu has said this in the Official Bambu FB group:
Updates and Third-Party Integration with Bambu Connect
Setting the Record Straight About Our Security Updateblog.bambulab.com
Honestly I don’t.Sounds like Greek to me. How much do you trust them David?
