Former Member
Guest
I think that applies to Canada as a whole, I would make a further comment, but thats political.Ya in Alberta getting a new liver might be easier than finding a new doctor
Definitely time for a second opinion.I think I'd get a new doctor.
Helium, as stated elsewhere, isn't flammable. Were it hydrogen, I suspect at 35K-60K ft altitude, there would be enough of a lack of Oxygen, to prevent the flammable gas (weather balloon story above) from being able to burn anyways. The normal load for aircraft guns is tracer ammo every fifth or so round, with various other fillers ranging from solid metal target practice rounds, on up to armor piercing incendiary, shells, and a bunch of options in between, so there would have been lots of fire to ignite the stuff if it was able to burn.So this is just thinking. No math, no relevant knowledge, nothing.
Could it be that helium simply isn't flammable at that altitude? Not enough oxygen maybe? Too rich, too lean,...... Etc.
Maybe a bullet at that altitude doesn't get hot enough to ignite anything?
Lots of potential explanations.
Helium is an inert gas and is not flammable. Did you mean Hydrogen? In any case I'm guessing whatever lighter than air gas they use is going to collect at the top of the balloon. Unless you puncture the very top of the balloon some of the gas will remain and keep the balloon afloat.
Something would have to “spark”, though, to ignite any gas, whatever the altitude
Just like you can throw matches at a pail of diesel all day long, with no other catalyst present it won’t light
Heat by compression of the air! And it requires a very fine vapour, (thus the Injector nozzles), even then, for it to ignite reliably.Ya, brain fart. Had a rough day today. Had an angiogram and sent that message from the waiting room. Obviously not thinking straight. I meant hydrogen.
Given the above, I'm not sure it's wise to say anything. But with some trepidation.....
Not really. Diesel ignites simply due to compression. No spark required. Most flammable chemicals have an ignition temperature at which they will ignite without a spark. But you are right, a spark is a more reliable method.
I believe this is where you wish we had that bird flippin emoji......![]()
Called a fire piston. Yep, same deal. Heat by compression. Needs to have some fuel in there to light, though.A few years ago, my son got me this African firestarter. It's a close fitting wooden piston in a hole in a block of wood. You put a small amount of tinder or punk wood in it and then slam it on the ground. The high pressure ignites the tinder. No mist required. The temp increase associated with the sudden high pressure is all that's required.
Diesel will also ignite without any mist provided that the mixture is within the flammability range for that pressure/temp. In fact, vapour is preferred over small droplets. Of course, a mist is better than a pool of fuel for that. There are many ways to accomplish reliable ignition in a compression ignition engine.
It's a subject I dearly love because I spent a chunk of my career designing engines in the auto industry.
In this case, I was only trying to help others see why a bullet might not ignite a balloon of gas. My examples might not have been the best choices.
Meh. Met an old deaf watch repair guy out in Regina SK. His wife was pretty straight up about our making deals. Said we should make what deals we wanted, because after he kicked it, the first guy to the front door with a truck and a $20 bill, gets it all!..... About the time you figure it can't get any worse..... Try and remember, poor @trevj is only a couple miles up the hill from me......![]()
Pretty sure she was more than half serious, too!
Her view is to pay someone to gut the place so she can build something totally different.
I find it great how no-one makes much of an effort to stay on topic. It makes posts more like a real conversation…
