You can add a pdf attachment by using the "Attach files" button.I recently emailed @Tomc938 a note about making acetal lead screw nuts. I can't upload the pdf here, but you make want to consider this route. I'm not sure how or if I can post a pdf on the forum.
Great idea!Voila!
I have not tried this myself, but have heard of nothing but good results.
Still did not figured out how to squeeze halves of nut with flange evenly on the lead screw.
Well... It is getting close to making an acme tap...My sonewhat lousy suggestion is to make a short duplicate section of your leadscrew, then squeeze a full nut onto it. Then unscrew the full nut and cut the nut in half.
Might be easier to single point the nut a bit loose first, then squeeze it to fit.
Also - nut consist out of two shapes/parts: cylindrical part and flange. How to squeeze it evenly on screw ? Any bright idea ?
I'm not understanding the picture. Why is the material marbleized? You melted different materials & squeezed it into a female mold or something?Short update - I prepared some HDPE as a test to cut or "melt on"
It is just different colours of the same HDPE. Some bottles, containers, other HDPE stuff. I was checking that it is not mixed types of plastic. I cut all bottles into small flat pieces and filled up cylindrical mold ( small LPG cylinder) . When plastic became soft and sticky (it is never melting into liquid) I pressed mold in with fitted cap. That is why it looks like twirled.You melted different materials
Indeed not. This is parts to try single thread cutting like Susquatch suggested and I think this is right way to go. I am currently gearing up for single thread cutting - ground bit to a suitable profile, prepared boring bar, already cut short piece of male lead screw. Quite a chatter, several times missed thread dial indicator, several times stalled the lathe with too deep cut... What a drama !!!but I'm not at all sure that HDPE will behave like Acetal does.
It took me a time to learn how not to miss thread dial indicator - I am holding threading level very close to be engaged but not just yet and "feel" when it is ready on Dial, so slightly pressing in. Usually half nut readily locking on a thread.
It looks a bit messy due to "marbeling" colours and twirls, but profile and dimentions are OK.
LOL . No any hidden agenda. I had several plastic bottles and containers made of HDPE with different colours. i chopped them into relatively small pieces, mixed altogether and then reheated and pressed into form. That has created that "marbleized" look. It holds together very well, though. No splitting, delaminating or anything else.Just curious, what are those marbeling colours all about? At first I thought it was blown glass art! Then I had to correct my perspective from a black button to a threaded hole. Very cool!
It is close up camera barrel distortion. End is perfectly square , I verified 🙂threaded hole also looks like a button cap?
