Working on my South Bend 9C
. I'm particularly concerned with your comment about "placement of the level!".
Mostly I meant if I didn't have the level perpendicular across the ways eg: rotated left/right when looking at the ways from above.
I did take that set of readings several times with no adjustment of the bed, just moving the blocks and level from HS to TS placement, and it was consistent across those.
You can see....
1. About .001" runout at the bar near the headstock.
2. About .002" runout at the bar 9.5" away from the headstock.
3. About .004-.005" when traversing the ways. The dip below 0 near the headstock is curious.
I'm kind of lost now. When you say runout, you mean the test bar is back in the spindle, you have the indicator centered on the test bar, you are rotating the spindle & you are seeing this needle +/- max deflection? So 0.001" near HS & 0.002" at 9.5" ~bar end? So 0.002-0.001=0.001" difference over the bar length? That is significantly more axialy aligned to the bed than before. What happened to 0.016" or whatever the huge number was when you traversed down the same bar & even rotated 180-deg to null a bent test bar?
Just to confirm, where is the indicator base set on? Is it on the cross slide base or is it up on the toolpost/cross slide?
Yes that's what I'm reading.
I mentioned but there's been a lot going on, that initial set of readings was accidentally with my metric dial indicator, so not 0.016", but rather 0.16mm or something.
Indicator is mounted to the AXA toolpost via adapter.
Another small data piece. I wanted to take a closer look at spindle/alignment bar. I marked the high points at both ends of the bar, and checked at 0/90/180/270 compared to the spindle mark.
The high points correspond to the mark on the bar NOT the spindle. So that's good re: spindle.
Now. Do I trust this alignment bar enough or do I need to find some stock for the dumbbell
The truth is that I don't trust those test bars so I'd make a dumbell anyway.
If you must use it, then remember that it probably is not aligned with the axis of your spindle. But it is the spindle you are trying to align, not the test bar. So, you would find the center axis of the test bar using a DTI, and then calculate where the axis of the spindle must be. Then you can use more measurements and calculations to determine how much the axis is off.
If you make a dumbell, it is already on the axis of the spindle. So you can directly measure how much it is off.
The only material I have that might make sense for a dumbbell test is some mystery 3/4 steel rod. Would that be suitable?
The problem with this setup is your indicator sitting on toolpost will be affected by anything underneath that can float in the cross bed orientation. Indicator >toolpost > cross slide > feedscrew /nut backlash.
Recall, I commented on the needle twitching as you were turning the handle traversing down the bar. Assuming thsi same setup with dial on the bar, tug/push the top of the tool post, what does the dial say? If its moving +/- 0.005" or 0.010" total, this completely obliterates the 0.001" readings you are doing at different positions down the bar. Do this test & tell us the amount, it will be educational. But after that, attach the mag base to the saddle itself becaue it can only be affected by saddle/V fit which should be a teeny tiny amount.
so we are dealing with 0.16/25.4=0.006" with the test bar never 0.016"?
and now you are getting 0.001-0.002" on the exact same test setup?
I dont understand the sequence of measurements & bent bar conjecture. If you measure +0.008" runout at end of the bar, rotate the spindle 180-deg, shouldnt you be seeing the same amount of runout in opposite direction <0.008">? This is the first thing you check for bar trueness. Make a sharpie mark on that max runout spot, remove the test bar, clean it or whatever, re-insert into spindle with same axial seating tap because an inconsistent MT fit on a 100% straight bar can look like the same thing. Do you get the exact same runout reading on the exact same spot?
@PeterT haha oh boy, .05" of movement when moving the toolpost!
Do you have a cross slide lock, something that clamps the cross slide gib strip or whatever - ultimately mechanically secures the cross slide once you have dialed in a DOC amount?
Because 0.050" is a LOT. Hopefully missing zero (like 0.005") or metric dial reading boo-boo? If its real you need to address that. Think about the max potential drift. 1.000" dia on one end + 2 * 0.050" = 1.100" dia on the other end. It may not deviate this theoretical amount but highly worn feed screw / nut creates havoc like this where the cross slide can drift. It takes the cutting tool along for the ride & you have wonky unpredictable surfaces.
