The setup Susquatch is showing in #1690 is the classic twist detector. You observe angle readings at stations along the bed & compare the relative differences. The important thing is to use the same setup for the complete session. Dont swap in different blocks or risers. Also, good idea to mark off some felt pen station lines down the bed like, I dunno, 4" apart so that you can replicate the readings at those stations & will help with data outliers or averages if you have other issues. Because presumably you will be doing some kind of mechanical adjustment & then repeating the measurements to re-map the bed, compare to prior & hopefully converge on the best twist minimization compromise.
Refering to the sketch below - the next part almost goes without saying, but shockingly is worth mentioning because many people get it wrong. Probably because of that f*cking 'level' word again. Lets say you started at front plane & worked your way closer in this this picture. A) you measure 0.00, 0.10, 0,20, 0.30, 0.40 deg (a constant twist progression). Is that any different that B) 0.35, 0.45, 0.55, 0.65, 0.75? Answer: No, not from a lathe bed twist perspective. They are identical. Each increment is 0.1-deg apart & the total twist is 0.4 deg over the range. In A, station zero happens to be level to the horizon, plumb to the world. Heck even the neutral axis of twist can be level. WHO CARES! It is not addressing twist. Now if you want the lathe to be plumb with the world for some reason AND no twist, thats fine. Probably best to do some initial coarse jigging of the feet or whatever. But for the initial mapping where you are trying to get a handle on current cutting issue problems, just map it the way it is & see what you are looking at. If you have twist, then temporarily fix it & confirm with same readings down the MT test bar. If you happen to have a very planar bed, its putting even more suspicion to HS rotation as primary cuplrit.
Next scenario. Lets say we have bed droop, no twist as defined above. I'm showing it as droop on one end but it could just as well be droop in the middle of the bed. What will the above cross-bed angle test show down the stations now? Likely 0.00, 0.00, 0.00 or 0.20, 0.20, 0.20.... So if we ended the above test here we would have false conclusion the bed is 100% planar, but clearly it is not planar. Now you take the same instrument but you need some kind of base to hold the level. A sine bar is good because it has 2 dowels making tangent contact to the bed. Now re-orient the level along the way statins & repeat. Probably you would see somethng like 0.00, 0.02, 0.05, 0.07, 0.09...
Now I'm kind of contradicting myself because first I said the vertical deviation (droop or rise in the Y-axis) factors less than twist. But that was confined to cutting taper on cantilever stock as being the more predominant effect. But since you already have the measurement equipment out, do it for knowledge sake, and also because it can factor in other respects. This is another tangent so I'll just end it here for now. get to this point & then see what the data says.
