Working on my South Bend 9C
Looking for gauge pins, I'm pretty much just finding 2" length
Yes, that's the normal length. This is what you need for regular concentricity measurements.
To measure axial concentricity you need a longer bar. I don't know if you can buy one. I would think ground bar would be fine but I can't find it. I did reach out the that outfit you flagged earlier but they just want to sell bar and don't want to tell me what level of precision they are. The email chain keeps growing.
A full scope machine shop can grind you one but probably for $$$.
I would think that linear guide bars would work, but I don't know that for sure.
I cut my own but I don't need them to be what you need because I have pretty good metrology capabilities here. You don't have that so you need a known good bar.
You have shown that your reamer shaft isn't up to the task. So we just need to find something that is. I'm pretty confident that the group here can do that.
In the meantime, keep looking!
Wrong application. O1 drill rod is basically high carbon % 'stock' in annealed form. It is used to make things from whuch are intended to be hardened by heat treatment. The abbreviations O=oil, W=water A=air refer to the quenching medium. It is OD ground on DIAMETER (only) with stated +/- 0.0005" tolerance. But it says nothong about it being axially straight. It comes in a cardboard tube, for that matter sitting under a pile of other packages.
For hoots and hollers I tossed in that MT3 alignment bar. Obviously I don't know if it's good, but I think it might point somewhere.
Here is me indicating along it at two points 180° apart. Both times it seems to angle the same way, so probably not a bend in the tool. And the tailstock was off center too corresponding with that (it was aligned close to the headstock, and is off way back.
I'm sure I'm overlooking something (and no I don't know the quality of the bar), but it certainly *seems* like I've got a spindle/bed misalignment.
I agree. Since it seems to point toward the operator at both 0 and 180, and assuming the bar is a uniform diameter, that does suggest that the headstock is pointing toward the operator.
Looks pretty bad to me. Certainly bad enough to Fk up your arbours.
Dare I ask why the lathe wasn't aligned before you started using it?
Now we have to determine whether the bed is twisted, or bent, or the headstock is pointing wrong.
