Golem Pens
Michael
I need a travelling machinist repair person to come by and help. I would absolutely pay for that service!
Got it, will do. A few clarifying questions:
1) You no longer want a deflection test, correct?
2) For my specific DTI, how would you want this exemplar reading recorded? With the red arrows indicating the two extremes of the dial sweep.
- 10.1 to 5.4?
- 13 ticks?
- Other?
So, to make sure I follow.Yes, I am happy with your deflection results.
Other. I just want the actual reading at that specific angle. In other words, where is the needle pointing on the DTI when the reamer is rotated to that angle.
I am NOT adjusting the reamer in the collet (I had been doing that before).
I am simply rotating the spindle to 45° intervals and taking a static reading at each (I had been taking readings in motion before).
| Angle | Collet 1 | Collet 2 | Extension 1 | Extension 2 |
| 0/360 | 6.25 | 6.25 | 4.6 | 4.6 |
| 45 | 6.25 | 6.25 | 2.75 | 1.5 |
| 90 | 6.25 | 6.25 | 1.5 | 1.5 |
| 135 | 6.25 | 6.25 | 3.0 | 3.0 |
| 180 | 6.3 | 6.25 | 6.25 | 5.0 |
| 225 | 6.8 | 6.8 | 8.0 | 7.0 |
| 270 | 7.0 | 7.2 | 8.0 | 7.2 |
| 315 | 7.0 | 7.2 | 7.8 | 8.0 |
But as Peter noted this could be a poor reference tool (not that I have anything better currently).
Is "precision ground" rod from McMaster or elsewhere (eg: https://metalsrus.ca/products/carbon-round-bar-5-8-1045-pg-a108) viable or does that mean something else?We need to get you a good bar. Preferably 5/8 diameter like your pen arbours and 6" long or so.
I hope yours is better than mine. The morse taper on mine is very poor. I wish I could get it properly reground (or even afford to get it reground)....new one is probably cheaper and better🙄And the alignment test bar literally just arrived. I'm skeptical of it (Amazon), but it's probably worth trying.
Not holding my breath, but I figure it's worth a quick test tomorrow and a return if it's crap.I hope yours is better than mine. The morse taper on mine is very poor. I wish I could get it properly reground (or even afford to get it reground)....new one is probably cheaper and better🙄
Ditto. I have a Made in India special. Its ground very shiny & the diameter is within tenths all the way down. But... it went banana after a couple years, stress relieving itself I suspect. The theory of them is good if you happen to have a reliable one. An brand new offshore model can be had for under 50$. A Suburban or USA model is like 8X that. We have discussed this many times.I hope yours is better than mine.
Open to somewhat affordable recommendations!I don't personally think they are a good tool for lathe alignment.
