Dial reading shows travel, not depth of cut. So one thou on the dial reduces the work diameter by two thou.
Ah, I see. I wish mine was like yours. Mine reads diameter reduction. I am quite capable of calculating diameter change from a cut dimension. I want to dial in depth of cut not diameter.
All the other dials are travel. They should all be like that.
I think it's easier to internalize a diameter change from a depth of cut than the other way around. I would think that you will get the hang of it easier with the way yours works.
