Jswain
Joe
If you get a 4jaw situated and the mt3 er collet chuck
With the 3jaw you can always mount the backplate. Skim cut all the faces, then orientate the chuck thru all the mounting hole possibilities & you will likely find a combo that works as well.
Then when you fix the spindle with a press(or heat/cold) on bushing you will likely just need to reskim cut the 3jaw backplate.
No reason to give up on the lathe yet
