Working on my South Bend 9C
Hi Michael,, Guys,
You could always buy a short length of bronze bar if you could get someone to machine it for you to accurately fit the new spindle. Machining the outer diameter wouldn't be as critical since the clamp can be tightened.
The post # 630 by @gerritv has measurements, this shows a spindle with a shoulder, however, the 1;5 X8 spindle nose is somewhat universal I think. It appears to show a thread length of 11/16 inch, a length of 7/8 inch from end of spindle to shoulder. I say appears as my eyes are still not over the pink eye bout.
These measurements could be confirmed by the other spindle. Have you tried the other spindle in your 3 jaw chuck mounting plate to check fit?
As @BaronJ has also said a bushing could be made for the “new” spindle. There was a picture of 2 pieces of bronze? stock shown in post #500 with a spindle, could the larger piece make a bushing?
Thanks @JustaDB, it seems that a cold can be a carrier for pink eye, but pink eye comes in 2 flavours, a virus or a bacterial infection, I look LOL, barely, to have the viral one. So a waiting game— 7 days, as one eye got it about 2 days after the first one, about 9-10 days.
Anyway don’t want others to get this Kurap, and I would have SEE to round up some good beer. Gee, I have some gluten free stuff you could try, NOT, don’t know who thought it was beer, but I was stupid enough to buy it. Going to see if it will clean the drain in a while!
Anyway, thanks ,but another day. Though, I remember the livestock not liking that spray very much.
Oh yeah... It's not compatible. I believe it's a more recent style than my lathe needs. The OD is smaller and I believe is intended for use with the generation that uses bronze press-in bearings (mine rides directly in the headstock).
If there is no collar then what prevents the thrust to the left. Are there some sort of thrust bearings on the other end?
There are, yes. I'll grab a photo later, but basically from left to right the full assembly is...
End with change gear > lock nut > left headstock > thrust bearing > spindle cone > bull gear > right headstock > spindle nose
Well it looks like 8 tpi, and 1.5" OD. If I'm reading right. Weird, if that listing is accurate
Well it looks like 10 tpi, but 1.5" OD. If I'm reading right.
Am I misunderstanding? Have you discovered that it's really 10 tpi, not 8? This would explain a shit load of runout....
A threaded connection is supposed to ramp a significant number of 60 degree threads against each other. The 60 degree cone surfaces self align as tension builds. The register forces a final alignment. But the register prolly couldn't fix an incorrectly matched sequence of threads.
Disregard for now. Possibly but I don't trust my measurements so I'm picking up a new thread pitch gauge.
Based off what I have now found elsewhere though it is a possibility.
I see! Thread gauges are not always that great. You can't go wrong just measuring them. A Vernier from point to point or valley to valley over as many threads as you have and some simple math will often be much better than a thread gauge. Just remember that you have count intervals not points. That seems to be a frequently made error.
Yeah I counted 5 points to a half inch and then remembered that which is why I said disregard until I reconfirm hahah
Yes use a caliper & encompass as many threads as you can. Photo parallax can be deceiving but something looks fishy. You can use this calculator to generate all the specs for ACME thread, OD, PD... by various class of fit. It says Fc = 0.0463" Just eyeballing yours maybe 25% of 1/16" rule increment = 0.016" ie. very sharp. Hard to image it could ever get worn like a leadscrew, <gulp> re-cut maybe? If the actual part is something other than an ACME you should be able to replicate with an online tool. Measure PD while you are investigating, easy to do with a mic & 3 wires.
More archeology....
Early models did use 1-3/8"x10tpi at my bearing dimensions.
Later models settled on 1-1/2"x8tpi at the smaller diameter bearings.
And there is some documentation of transitional variants using the larger bearing and 1-1/2"x8tpi combination. A very odd duck, and likely not going to find a replacement.
The bearing diameter difference is about 0.025". Otherwise the "modern" spindle is the same length and everything else as my current one.
What does the bore look like on the threaded end? I just cant see welding working out without a lot of heat related distortion issues, but I have zero experience. I think you would stand a better chance of machining the threads off or nearly so to make a new surface, add a 'new' oversize collar & re-cutting the surface to spec or desired thread. The collar method has downsides too but its mechanically cold. I suspect you could get away with radial cross pins & strong bearing retainer for good measure. But how hard is the spindle core? Another question is how much meat is left given the spindle bore/socket ID? Of course this would have to be done on another lathe by someone that knows what they are doing. Maybe a 'somewhat close' spindle could be the lucky organ donor? The spindle & its rotating assembly is the beating heart of a lathe.
The bore is in somewhat poor shape, it's certainly be mucked with in the past. Cleaning up the outside and re-extending the register surface with a collar seems.... Plausible.
