Tips/Techniques Which way to make this?
Tips/Techniques
jcdammeyer
John
The width of the channel is only 7.5mm. I'm thinking the easiest way to cut this is with a 6mm end mill on the CNC mill.
The slot has to hold this radial thrust bearings and the two thrust faces.
I could chuck it up on the lathe afterwards and clean it up with a very small boring tool. Since it needs to have the holes drilled again the CNC mill is the more likely option.
Optionally clamp the outer round part into the rotary table and just manually turn it to take out the slot and then drill the holes.
The work order and what tool to use is what has me wondering what an experienced machinist might do.
For ease of setup I'd use the rotary table. Basically one setup for the groove then use your dro or math it out to make the holes.
Work holding so you don't have to move clamps is key.
So I did use the boring tool to enlarge the recess for the head of the socket head screw. Didn't have anything that was 11.5mm diameter.
Had an old piece of aluminum riser from a casting project. Yes it has some porosity but that doesn't really matter much for this. Turned it to size, drilled the hole, bored the recess. Cut it off and flipped it and turned it to the correct thickness.
Now to figure out if my 3 jaw on the rotary table can have the jaws flipped around to hold it. Otherwise, backlash or not, I can use CNC to make the groove and certainly easy enough for the 6 holes.
Three options. LinuxCNC, DRO-350, Rotary Table. All three will let me drill and tap the 6 holes with LinuxCNC being the easiest.
Tomorrow...
So it's done.
And I remember why I like CNC so much more over manual work. Really must put ball screws on the mill. Then I can break tools at full speed and accurately. 🙁 So slow and tedious doing it by hand.
Anyway. Using the rotary table to turn the part and cut the slot with a 6mm end mill worked fine even if slow.
Had to flip it over to drill the 6 holes and not interfere with the chuck jaws. Just unclamp the quill and use the handle just like a drill press. Turn table 60 degrees and repeat.
Tapping was easier to get nice and upright using CNC (metric 4-0.7mm thread on imperial configured machine).
S50 M3
G33.1 Z-0.37 K0.0276
G80
M5
Turn rotary table 60 degrees. Rinse and repeat.
And installed
Here's the beginnings of the next piece. Should have taken a before photo. Not sure if it was a casting or something else. In either case cleaned up all 4 sides. Still way bigger than I need but it was free. Wasn't worth the time to get it totally cleaned up on that one edge.
The 3D printed 8mm shaft on the side is just not strong enough for the load put on it by the toothed belt when it's tensioned. Plus the set screws dig into the shaft.
So now that I have a big chunk of aluminum that has this part buried inside the question is how to find it in there.
1. Machine the rectangular dimensions without the motor faceplate slot.
2. Grab it in the 4-jaw, centred for the shaft lines and turn the 17mm end.
3. Grab the 17mm section in a collet and turn the 8mm shaft.
4. Then move to the mill, drill and bore the center hole and the small holes.
5. Mill out the slot for the motor faceplate.
Suggestions for an alternate approach?
Also what's interesting is the name of the part is "J6 housing single piece" but there aren't any drawings for J6 housing made up as two pieces. I've thought about just making the 8mm and plate section out of say brass but fastening it onto that body then raises a new set of problems. Mainly mounting it and keeping the shafts concentric.
Marked out, centre punched, aligned in the 4-jaw and centre drilled. Then I also drilled the 5mm hole for the 6-0.7mm screw.
Next the live centre and set up the ELS to travel exactly 0.720". Multiple turning passes with 0.025" depth of cut on each pass.
There we go. The shoulder is done.
Now to turn 0.661" down to 17mm for the ID of the tapered roller bearing.
After a coffee break to think about what I'm doing...
Dang it, that's where I go wrong. I always get it backwards and figure I need to sit down, have a coffee, and think what I'm doing, first.
Of course if I do that I usually forget what I'm supposed to be thinking about, get all distracted and wander off doing something else.
I guess I should have had a longer coffee break.
The hole the motor goes through matched the diameter of the printed one which was a smooth sliding fit. However, I don't know how I did it but it's now 0.010" oversize. The motor slides in but has a wobble. Will need to put a shim around it so all is not lost.
Then turning the longer shaft down to 8mm I chose a much smaller tool bit to get between the live center and the end of the shaft. Since the tool bit was 3/16" square I wanted as little hang out as possible. Somewhere along the line I misjudged the tool holder which then chewed a bit of the square part.
And the original hub was supposed to be 17mm or a hair under for a none press but definitely close fit to the tapered bearing. It's more a of loose fit.
Oh and the slotted top that holds the set screws was about 0.010" too narrow so I took too much off and now it's not a close fit to the square motor frame.
All in all it will probably be fine but I really am a crappy machinist when it comes to being precise.
After the 17mm hub was cut the backing diameter done for the pulley side the part was moved to the mill to a ER32 collet holder and 17mm collet. In hindsight I could have gone right down to the 8mm shaft size but that would have resulted in an even larger section to turn to.
The most boring part was removing 0.6" worth of material using 0.025" depth of cut at a time. I don't know if the collet would have held that had I been more aggressive. Again suggestions or advice for doing this kind of thing are welcome.
Once it had the correct dimensions it was clamped in the vise and I indicated off the 17mm hub to find the centre line. Then indicate the surface and start drilling and then boring.
Once the motor hole was there it was back to the lathe to cut the motor pulley shaft down to 8mm.
The shaft is longer than the stock design because I want to put a support bearing on the end so the belt doesn't pull and bend things.
I highly doubt that you are worse than me...... 😉
Looks like you are having fun and doing your best to exercise the old noodle along the way. 🙂
My noodle feels very soggy lately. Still tomorrow it will be done and I can go on to replacing the other 3D printed pieces with metal. I have some old plate stock for one part. The rest will have to wait until I light up the foundry.
