The width of the channel is only 7.5mm. I'm thinking the easiest way to cut this is with a 6mm end mill on the CNC mill.
The slot has to hold this radial thrust bearings and the two thrust faces.
I could chuck it up on the lathe afterwards and clean it up with a very small boring tool. Since it needs to have the holes drilled again the CNC mill is the more likely option.
Optionally clamp the outer round part into the rotary table and just manually turn it to take out the slot and then drill the holes.
The work order and what tool to use is what has me wondering what an experienced machinist might do.
