What to do when a tap breaks in a hole??
Either way you do it the threads in aluminum are going to be messed up - can you weld it back up and re do the hole? Can you make the hole / thread bigger?
I did remove a tap once by TIG welding metal to the top of it and then just going backwards. This is by far not easy as the heat from TIG makes it brittle - you have to try to heat it a bit longer and anneal it.
With M3 size this will be very tricky to do - that sucker is tiny.
