The other place to look for enclosures is outfits that sell used industrial electrical supplies. They are not as good a deal as the ReStore but are usually half the price of new.
We have two Re-Use type stores near us, one by the cottage and one near home.
That's what I did, just mounted the PC power supply fan against a cutout in the side of the $5 (A1 Electronic Surplus) alarm box. I also stuffed in the other CNC related stuff: single board PC, BOB's, and three stepper drives. Tight fit, fortunately have not had to fix or replace anything yet and it's been quite a few years. Fingers crossed.Just need a nice e-box deep enough for my vfd, a bus bar or two, a line filter, and a big shutoff switch on the side, but not a huge foot print cuz it needs to go on top of my headstock and be aesthetic. I'd like to position the VFD so I can see and access it through a hole in the lid and still have the VFD fan vent to outside the box. I see no point in a fan to vent the fan.
Somewhat concerned about heat, but the AL heatsink is against the steel and so far no issues.
I really like these yaskawa drives, the technical manual is over 250 pages, every parameter and fault is explained.
They do have bigger models I bet there would be one that would handle a motor that size. The control panel can't be moved but all the inputs you need can be remotely wired and remotely programed. These are older probably around 12-13 years but with light use. I know of many that have been on 24/7 and running about 18 hours a day for those same years with no problems.I couldn't find a J1000. Is that an older model? Do they have a 3HP model? Can the control panel be put elsewhere?
Perhaps someone with the electrical specifications can chime in here. I think the way it's supposed to be done is the AC Mains power Ground goes to the box first. Then all the other devices in the box that have a ground wire are connected to ground at that point. Often the initial input ground is locked down with another nut and then the others are on top of that locked down with a second nut.There are two marked ground wires on the input and output of the controller and are tied to the chassis and the chassis of the controller is mounted to the box I guess I could run another line to the box I am not sure its needed. That is the way they were wired there was no separate ground point on the box.
Your description is accurate, and this is a sticky point for most ESA/CSA inspectors. IIRC the toothed washers are also mandatory, and additional ground wires must be above the nut holding the power in ground (so an additional nut required for additional ground lugs). Don't be surprised if the ESA inspector does not let it slide if any aspect of the ground bond is not as shown below. If panel is anodized instead of painted, same thing, easier to mask that area before anodizing.Perhaps someone with the electrical specifications can chime in here. I think the way it's supposed to be done is the AC Mains power Ground goes to the box first. Then all the other devices in the box that have a ground wire are connected to ground at that point. Often the initial input ground is locked down with another nut and then the others are on top of that locked down with a second nut.
I have 3 of this model. They fit the Teco VFD's that I used on my lathe and mill as well as the no-name one I used on my drill press.
I don't recall seeing that John. Can you post a few photos of the finished box with the VFD in it? Did you include a cooling fan?
Post #50
