Definitely not ER25.
This is a 1 1/16" drill bit in the 27 mm collet
The left hand side of the machine uses the exact same collets and collet holders as the MR-13X machines and the right side is basically that again, but scaled up. The split point on this machine is different from the 13A. I assume it's similar to the 13D, but I've never seen one of those in person so hard to say. Collets are stored in the drawer below the two depth setting fixtures and range from 3 mm - 32 mm and change collet type at 13 mm. Slightly annoyingly, the top couple sizes don't have a home in the drawer, but I assume that it was really intended to cover 3 - 26 mm, similar to how the MR-13X is meant to cover 3 - 13 mm, but eventually was offered with an extended range. Collet holders and collets look identical to the Vevor ones. When I was looking around I did my best to find the actual manufacturer, rather than a reseller. I can't be sure of course.
Oh and did I mention that this thing is fucking heavy. It's probably 75 lbs without the collet drawer in.
and of course a close up of one I did a split point on. Don't recall the size offhand. It took a little adjustment out of the box before I was happy with it, but just the usual adjustments. Didn't have to do anything weird like move where the wheel lives on the motor shaft.
I bought it from MRCM directly by contacting them through
their site. It was not the most straight forward thing I've done. There are listings on Alibaba or Aliexpress or somewhere like that, but I wasn't clear on exactly the configuration of the machine (voltage, included collets range, CBN or diamond wheel, etc.) through those links so I went direct.
