That is sweet. I would think you could figure out exactly how much compression to get exact size. It probably adds surface hardness also... Goodbye emery paper !!Nice use for a ball bearing to build a burnishing tool. I often work with hot rolled and it is hard to get a nice finish with HR material. I'd like to try this. I wonder how much burnishing changes the dimension.
Dang I wonder if that would work on my 12x37....
Would have to be reducing the diameter right?I bet it would.
I'd love to see a high magnification video of what is happening under that ball.....
Can’t find a macro video, but here’s some numbers:I bet it would.
Oh that’s way less than I expected.Can’t find a macro video, but here’s some numbers:
My math says dimensions won’t change much. 125uRa roughness is pretty gross, and if the cogsdill description is accurate, smoothing out a 125uRa machining finish would squish down the peaks and fill in the valleys, so maybe reduce the O.D. of a cylindrical piece by half of the Ra value. 62 millionths of an inch?
That is awesome! I didn't know about this at all. And definitely on the to do list now! What a cool project and he is an excellent machinist.
Obviously I know next to nothing but it seems to me that the hole only needs to be small enough contain the steel ballThat is awesome! I didn't know about this at all. And definitely on the to do list now! What a cool project and he is an excellent machinist.
There is a tricky bit though. The nut which holds the ball bearing captive I have a few questions... What size is the hole to keep the bearing in place? Why dosen't the bearing rub on the housing? The nut seems to cinch down to the bottom of the threads yet the ball can still move around. What might the clearance be?
Would this work on aluminium too?
Not that bearing. The steel ball. definitions .... argh I don't have clear words.Obviously I know next to nothing but it seems to me that the hole only needs to be small enough contain the ball bearing.![]()
I suspect there may be washers holding the bearing in the middle of the slot?
I think the bore for the bearing needs to be close tolerance so that it’s not rattling around.
Sorry my explanation mixed metaphors or at least balls and bearingsNot that bearing. The steel ball. definitions .... argh I don't have clear words.
This is a ball bearing says google:
from https://www.theengineerspost.com/types-of-bearings/
McMaster says these are steel balls.
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
Ok I'll rephrase now that I know what the names are.
Questions:
There is a tricky bit though. The nut which holds the Steel ball captive I have a few questions... What size is the hole to keep the ball in place? Why dosen't the ball rub on the housing? The nut seems to cinch down to the bottom of the threads yet the ball can still move around. What might the clearance be?
That’s what I found when I just for laughs and giggles tried one out a long time ago; actually I was too lazy to change the insert back to steel after working in ALU. I only had one tool holder at the time…I recently received and tried some round Inserts for cutting Aluminium. I was blown away by the improved finish on hot-rolled steel. I have more experimenting to do but for right now I'm just plain amazed.
I am not sure about that: depending on the ball size, there is a very small contact area that does the work. I would be surprised if the forces are any higher than during regular medium to heavy turning.I bet this process is really hard on the cross-slide screw and nut. Not something I'd want to do very often. I like my lathe too much to do that to it.
The forces would be larger than using just a ball because of the larger contact area.
