Have had it in the shop for a couple years now.
This one doesnt get enough use to justify the footprint it is taking up.
Located in Vancouver, BC Canada
Specs1100M base mill
PathPilot CNC controller
Free PathPilot updates for life
Mill stand
Toolholding set
ViseLCD screen, mouse and keyboard
MSRP: $19,552 USD($27,741 CAD)
Machine Dimentions
Table Size: 34 in. × 9-1/2 in. (863.60 mm x 241.30 mm)
Table Slots: 5/8 in.– Three slots (15.875 mm)
Spindle Nose to Table Max Clearance: 18 in. (457 mm)
Spindle Centerline to Machine Column: 11 in. (279.40 mm)
Typical System Footprint: 69 in. × 56.5 in. (1753 mm x 1435 mm)
Overall System Height: 96 in. (2438 mm)
Typical System Weight: 1600 lb (726 kg)
Maximum Weight on Table: 500 lbs (227 kg)
Power
Power Required: Single-Phase 208-240 Vac, 50/60 Hz, 20 A Breaker, NEMA 6-20R Receptacle
Travels
X-Axis: 18 in.(457 mm)
Y-Axis: 11 in. (279 mm)
Z-Axis: 16.25 in. (412 mm)
Spindle
Spindle Power: 2 hp (1.5 kW)
Maximum Speed: 7500 RPM\
Transmission: Poly-V belt
Spindle Taper: R8
Tapping: Tension/Compression, Auto-Reversing, Thread Mill
Maximum Feed Rate
X- and Y-Axis: 110 IPM (2.79 m/min)
Z-Axis: 90 IPM (2.29 m/min)
Mill stand
Toolholding set
Machine Dimentions
Power
Travels
Spindle
Spindle Taper: R8
Maximum Feed Rate
