Like this? https://littlemachineshop.com/products/product_view.php?ProductID=2018&category=
I just use a dedicated wrench on mine
That's exactly the set up I have, except for the bottom washer and nut.You need a way to adjust the pre-tension on your set-up.
It could be done like this:
The adjusting nut is used to fine tune the lever movement once the TS is installed on the ways.
Very clever idea. Will have to dig around my spring box for something suitable.The genius part (if I may say so myself) is a small coil spring between the lock plate and the tail stock housing. never hangs up or drags
I most probably have one for you. Just confirm the size and I’ll have a look in my stash of metric fasteners.There is probably a M10 or whatever it is nyloc nut out there in the universe for me, but I'd probably have to buy a bag of 25
It's a 10 mm, I got 1Once you find out what size it is, let me know.
The only issue I have on my TS clamp assembly is the main nut slowly unscrews from the threaded post over time, so it drifts lower & that affects the cam action on the TS tightening handle. I might have enough thread for a second jamb nut principle (green). I also thought about cross drilling a few holes in the nut (red) & using a brass or nylon set screw against the threads. Enough light force to retain, but not enough to bugger. There is probably a M10 or whatever it is nyloc nut out there in the universe for me, but I'd probably have to buy a bag of 25
@whydontu is that the principle of the what looks like a cap screw head in your pic?
