The twisted pairs help, but maybe not enough from the amount of EMF going to and from the pot?
I initially did have separate wires but they were run along side others.maybe try using a complete separate set of wires for the pot and the tach display. So don't use the same cat 6 cable group for both. try some separate jumper wires for the tach and run the wires in a different route not side by side. If am understanding your setup correctly. I might have it wrong in my head.
Yes I have another duplicate vfd mounted in the same closure. It is for a drill press that will be wired the same way. I'm waiting for a motor for that one so we will see if it behaves any differentlyI thought I saw a post that showed you had more than one of these vfd's? maybe I am wrong, but if you did and you haven't had enough fun yet you could swap out the vfd.
Yuppers. That's what it was! I did a quick rewiring job with my old speaker wires on the potentiometer and made sure the tach was powered with a twisted PAIR and presto everything works as it should. Alle-frickin-luia.
Oh actually I haven't tried that (embarrassed) but it works now with external power AND the potentiometer so I am assuming all is well but I guess I will never learn about making assumptions. I will report back once I get it rewired to try that.And powered from the VFD? Everything is working as you want now?
Yes the tach wiring issues almost got the best of me but I'm glad I persevered. I used 20 guage sheet metal for my boxes. Yes I made the vfd cabinet as well but the side the door is hinged on could have been made a bit more ridged. I used only one center hinge because that's all I had but two would have been much better. The fan in the top of the box runs whenever the vfds are powered and the fans on the vfds themselves only come on when the vfd is actually running the motors. I powered the extra fan of the vfd ports.@DPittman looks great! Glad you got the tach to workout. Did you make the VFD cabinet as well? Great job on the boxes, what thickness sheet metal did you use?
At first I thought you had a mask on in the video, then I realized it was just your phone.![]()
