I thought I would start a new thread to glean some ideas to help me avoid some mistakes I'm likely to make with out some input from those that know stuff that I don't.
My plan is to mount two recently purchased vfd's in one protective box on the wall and then remotely mount the control panels on the machines themselves.
One vfd will control a milling machine and one will control a drill press. I thought about using one vfd for two machines but the vfds were so cheap I chose to use separate vfds for each machine.
I think I will have a master switch between power source (220v) and the vfd's. I am then undecided whether I need another switch on the machine or if the vfd panel stop/run button is enough for each machine.
I am wondering if it would be ok to run power line to the first vfd and then just wire the power over to the next one beside it? I won't ever be running the two machines at the same time.
My milling machine already has a forward/reverse switch on it....that gets removed right because the vfd has that built in?
