I need a piece of shafting 1" in diameter 3 feet long. Final product will be a bit shorter but will buy 3 feet to get started. I'm making a grinder that will have 6 eight inch diameter grinding wheels. The shaft will be supported with 2 pillow block bearings near the middle and driven by a pulley in the centre. If it does not run true I can add additional bearings on the ends. Shaft will be turning at 500 to a maximum of 1500 RPM. It will be exposed to pure water with no lubricant in it.
Does anyone know where I can buy some sort of ready to use shafting? Recommend a grade of metal? I will have to do a little machining on the ends. I want something with no runout as supplied.
