Some pictures of possible interest
@Susquatch : the hubs and components are particularly large for the ice breaking requirements of the vessel and also the response time for the propeller - as you mentioned full ahead to full astern.
The props can rotate through the full say 60 degrees in roughly 12 seconds regardless of the loading or shaft speed. Given that the design of the ship is in the off shore tug category we are designed to push and pull oil rigs, set anchors and we even had a large foam induction fire fighting system that could drop 600 cubic meters a hour on an oil rig (this was removed in 2016 as it was not used and suffering maintenance issues)
With 4 engines running we do 14.7 knots ahead (27 KM/hr). In heavy ice 3 feet thick we are supposed to do at least 3 knots - however, depending on the ice density we usually clip along at 6 to 8 knots. We were busting up to 52 inches in Superior with only 3 engines a few years ago.
The blades are pretty much impervious to cavitation, we are still on the same set after close to 10 years service without the need to recondition. That means we haven't hit anything hard like dead heads, rocks, submerged buoys etc that would tear blade chunks out. Our last issue with that was sucking in a 4" hawser with a big shackle still attached some Laker dumped in the harbour. We chewed that up pretty good. The props are fitted with a Kort Nozzle - that is a mini tunnel to direct thrust that would be lost off the blade tips. The nozzle is fitted with an annular band of stainless welding that prevents cavitation damage of the nozzle steel.
You can see in the above picture the anti-cavitation band, some blade damage and the ground up shackle. Divers cut it out with an underwater lance - sort of the same principle as a gouging rod on land.
Very very cool @Brent H ! Much appreciated! Keep it coming. I have thoroughly enjoyed everything you have provided. It's a glimpse into another world for me from the very viewpoint that I enjoy and appreciate the most!
Thank you @Susquatch and @YYCHM for the support and kind words. I am in my “working for the man” time of lasts - this will be my last Dry Dock so might as well show you guys a different perspective.
33 years ago I was like - WOW!! …. So much information and training etc so glad you appreciate some of the cool things!!
I will try to throw as much out there as I can !!
@YYCHM - LOL _not at this time. Already booked for a while. Word of mouth is pretty crazy and if you throw in the steel work.....Also just got a request to build another house next year (third one) ....crazy....retirement may not be quite that ....hahaha
If postal service wasn't so expensive in Canada.......................
So for the guys who like the heavy and awkward lifts: this is a pic of our tail shaft going in without the blades on. Somewhere around 14000 lbs. :D
Amazing @Brent H ! My head hurts picturing those straps holding 7000 pounds. Love the leveling chain fall on the one strap. How is it moved side to side?
Great pics Brent.
And then there is re-rigging to get the shaft all the way home, is that what all the chain falls hanging from the hull are for? How is the shaft being supported and moved inside the ship?
Last question - how long, time wise, is the process to reinstall the shaft?
If you look beside the head of the guy standing o the cribbing you will see a small square box. This is a digital protractor and he is setting he shaft angle to match the angle the stern tube is at. He adjusts using the chain falls that @Susquatch mentioned. The crane then swings things in as far as possible and other chain falls are applied for support and for pulling the shaft in. The stern tube bearing is slathered in soap and the shaft is inched along until the forward sleeve bearing is resting in the stern tube bearing. After that load is picked up on the other chain falls and the crane is out. Things then are warped along using the chain falls and straps. Takes about 4 hours to move things along. Normally the blades are on and the shaft can be inserted all the way, however, you need to take care to install all the seal parts inside and the coupling parts as well. The coupling is an SKF type that works : https://www.skf.com/ca/en/products/power-transmission/couplings/ok-couplings
Once the shaft is in position they cut off the lugs that have been welded to the hull for the lifting purposes. They will get ripped off during ice breaking so better to remove now. - each lug is certified and welded on by a certified welder.
Home a jiggity on Wednesday - Lobster is $16 at the airport so.........:p
When I worked on the arctic drilling rigs, we were two weeks in, one week out. Getting to site was an all day affair as was coming out. 5am AirBus to EDM (on my dime, it was like $80 one way back then), then company Electra (Ya Electra) 5 hr fight to Melville Island, then wait around for a twin otter flight to your destination rig. You changed out with a night shift guy so guess what you did for the next 12 hours when you arrived. It was brutal. The schedule didn't change if you got weathered out either which delayed crew changes up to 3 days, so sometimes you came home and turned around almost the very next day.
Send some of that $16 Lobster my way please:p
2 week on and One week off would pretty much shut down shipping at this point. LOL. Most trade jobs pay at least as good or better than mine - the home time is the deal or no deal (at least for me)
As in shutdown the shipping lanes or shutdown your interest in the job?
