I'm in the process now. This has an MT5 shank. My mill uses NMTB 40. The newer Narex units use interchangeable shanks that are bolted on with several bolts on a flange. This one is maybe an earlier model, and I'm not sure how it attaches. So we'll see once its all apart.A bit of clean up on that Narex and you'll love it.
Take some pics when the time comes, I'm curious.So we'll see once its all apart.
Accufinish Series II
Thank you for looking around. I did see that, but the stick-out of that unit is almost 7", then add on the height of the Narex boring head: 5", plus a cutter, say 2", thats 14". The maximum height of my milling machine from table, (let alone mill vise), to spindle is 18.5". So not an ideal set-up.McMaster Carr lists:
Nmtb Taper to Morse Taper Shank Adapter
Nmtb 40 Taper Shank for Morse Taper Number 5
Delivers in 2-4 weeks
$122.00 each
9343N14
Yeah, not quite there yet, but I did download a pdf:Maybe you are not quite there yet, but what is the nature of the abrasive wheel? Is it removable & replaceable with any of the inexpensive diamond or CNN offerrings from China?
I can see that as a problem. Very carefully chuck the head in a four-jaw until it runs dead true, then cut/grind the shank to the largest straight shank you can achieve. Then hold it in a nmtb collet for use.Thank you for looking around. I did see that, but the stick-out of that unit is almost 7", then add on the height of the Narex boring head: 5", plus a cutter, say 2", thats 14". The maximum height of my milling machine from table, (let alone mill vise), to spindle is 18.5". So not an ideal set-up.
