So I've jumped into the rabbit hole
Been printing parts for Canon EOS R cameras. Today I printed the longest piece to date. I have a 14.2” diameter part to be printed still in the design stage.
Pierre
Tonight’s print job. Finalized the design and this will make 6 of the 8 sectors needed to make the two rings on the upper section of the telescope.
Pierre
Just look at that printer! @pdentrem have you done any mixed diameter nozzle prints, say 0.8mm for coarse fast areas, and a 0.4mm for threads and lettering etc. How does that work out?
How are you using the multiple heads in practice?
I'd make sure it takes standard rolls. As far as I understand it, the Bambu doesn't take standard size rolls.
Maybe @jcdammeyer can weigh in on this.
I stand corrected, I think @jcdammeyer was having issues because of cardboard rolls from Matter3D which were also very full so they interfered with the guides.
That can happen with the AMS (the multiple spool handler)
Any oversize spool can just be mounted on the back of the printer. This also needs to be done with TPU filament.
Sometimes the AMS has trouble rewinding the cardboard spools when retracting the filament, mostly when the spool is almost empty and too light to be spun properly by the rollers under the spool.
OK. I've had BadaBambu now for a week. I've gone through 4 spools of filament already including reprinting two pieces but this time using the support filament which is only used as a thin layer between the actual printing PLA. Mostly the issue with the support filament doing curves that arc upwards is lots of swapping filament back and forth. This is where a multi-extruder unit would be more effective.
What I like most about the Bambu X1C though is that the bed doesn't move back and forth and so the XY motion is so much faster and smoother. What takes 2 hours on the SOVOL takes half that time on the Bambu.
The surface finish on a piece that was supported is simply amazing compared to the old way of doing it with the same filament. Amazon is supposed to deliver the 5mm diameter magnets today so I can put those into both the frame and the doors and then use them to correctly position everything when I glue the frame together.
I haven't decided yet if I want to use the 4xRed_1xBlue LED tape or the led strip with the REDish Blue LEDs for the grow light trays.
Also not yet decided on the plant probes and auto watering system.
Edit: It's 16"x10"x24"
And forgot to answer @DavidR8 question about spools. Bambu states that the cardboard spools can leave dust that eventually jams up the rollers. The latest filament I got from Matter3D in Langford is meant for Bambu so has a plastic spool at an adder of an extra $0.5 I think. But they'll refill the rolls so only really pay for it once.
After I figured out how to use non-Bambu RFID rolls that issue with loading a full plastic Bambu roll went away although they are noisier than the Bambu rolls. Last night at about 1:30AM my phone told me the 4th roll that I was using for a long print was empty. I went down, pulled out the empty one, installed a fresh new Matter3D roll and pressed OK. It loaded and then went on printing.
My SOVOL also stops but I've not set anything up with OctoPrint to let me know that it needs a filament change. I also get more spiderwebbing from the SOVOL. Not sure why.
