I ordered some from walmart I haven't received them yet so I can't comment on the quality but they do have a good selection
of sizes.
No, but you can order the DIY kit. Complete with instructions. (written like all the other instructions, in Chinglish)Machining tools at WALMART?
Isn't that sort of like a mortal sin or at minimum some kind of societal breakdown!
Do they do open heart surgery too?
LMAO!
Hmnn I might look into that, ya know a fellow has to save every penny he can.No, but you can order the DIY kit. Complete with instructions. (written like all the other instructions, in Chinglish)
I got some at Busy Bee years ago and they are OK.
Search: 11 results found for "slitting"
Busy Bee Tools offers top-quality woodworking and metalworking tools at unbeatable prices. Shop our extensive range online or visit one of our 9 Canadian locations. Enjoy expert advice, fast shipping, and exceptional customer service. Find everything you need for your projects today!www.busybeetools.com
Thanks Peter, do you have a link to the arbor?@David_R8 coincidentally I just ordered these from Ali, so should be in a position to tell you about quality when they arrive pretty soon. All they sell is metric saw widths but I'm OK with that. Actually for my (metric based) radial engine it caused me more grief to figure out new dimensions for IMP saws for cooling fins & such. I opted to try the 75mm OD blades & bought the appropriate arbor.
I've bought a few blades onsey-twosey as I've needed them predominantly from KBC in the past. But I started to get generally frustrated by the N-Am offerings. The blades vary in quality. The Euro ones have been fine but they come in certain dimensions that you need specific arbors. Then the shanks vary so you have to have the right collet or holder to marry to the mill. I've also had some made in India saws that I'm pretty sure were the tops of soup cans. They wobble like crazy even when the arbor is perfect fit. You can find some super duper USA arbors with low runout but they are crazy prices. Maybe used for CNC not sure. I was just preparing myself to make my own arbors because I'm confident I can replicate the accuracy (but not hardened/ground). So that's what got me looking at Ali. Fingers crossed. I have HSS coming but in other suppliers I see carbide for the price of HSS domestically. Your application may vary but I find small diameters might be limited in what they can cut. By the time you factor the appropriate holder, you may not have much actual saw depth. The Ali link offerred a few different flaours once you cross reference the saws, hole ID's, available arbor options etc.
5.75C$ 15% OFF|40 60 75 80 100 110 125 150 160 200mm Hss Sawtooth Disc Milling Cutter,high Speed Steel Disc Saw Blade Milling Cutter - Milling Cutter - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
