Has anyone ever taken one of these apart. Mine is getting old and rough. I want to disassemble for cleaning and maybe bearing replacement, Hint, tips, suggestions please.
I've watched a few videos but none of the methods I saw seemed applicable to this center. There is a cap that threads on (not shown) and I assume that was used to press the assembly in place. On the tail end there was a tiny (#10-24) set screw that I think was just a place to insert lube. I...
I did open it up. The bearing and shaft at the end opposite the center are really small and secured with a very small snap ring. I really didn't want to tap or press on it. It would be very easy to damage. So I flushed it really well with light oil (3 in 1) and re lubed everything. I think it's going to be OK?
CHEERS
CHEERS
