Show us your shops!
No columns in middle! It is currently 4 LVLs bolted together spanning the entire 31' with timber posts on both ends. Joists in between.
I did just inquiry about an I-beam yesterday and the building came back with a 1500-2000$ premium over LVLs for a W10-26. So I'm sticking with wood mainly because of costs but also would be easier if I needed to bold anything into the beam for other uses. I'm a little nervous about all these incremental costs that seem fine on its own but they all add up quickly.
A smaller beam doesn't necessarily need posts in the middle of your shop to support it. It could hang on rods from the roof trusses with relatively modest roof strength improvements. Depending on the span, they might be needed anyway.
I was worried about overloading the mezzanine and stressing the roof but this anxiety isn't informed by anything since I am no engineer and with limited practice of loading and rigging. I asked for clearance below so the proposed solution by the engineer and builder is closer to a gantry design as shown above with 4x LVLs.
Now I am thinking of one or two additional beams on the same plane. I can have a hoist towards the back and even build out another small shelf to store above. Looking for thoughts and suggestions from folks here!
One way to think about it is that all roofs in Canada have to be designed and built to handle the design snow load for that area. With the right designs to spread the loads the same way that snowloads are carried, supports for your mezzanine can be carried just like a bigger snow load would be.
Oh right! I'll talk the builder to see if a design to strengthen the roof without much much material or labour could be added increase the load capacity for the mezzanine with a few rod ties. But if all that gets close to the cost of a metal beam I may have to forgo... will explore it!
Except that snow load is assumed to be uniform (other than at drifting portions of the roof), wheras the hanging loads for the mezzanine (and/or hoist) would be point loads at the connections.
Yes exactly. That's why I said:
My error, should have quoted both posts: it didn’t seem that @architect understood that it would take more than adding a little material and some “rod ties.” I have encountered this even with experienced commercial real estate developers who are trying to rent out existing buildings: I have walked out of more than a few buildings that didn’t look safe after an occupant has hung high loads off of the roof structure (one was a new addition where the connection between the existing and new structures had separated by several inches, not and expansion joint).
Thanks for the caution. I am leaving it to the structural engineer to do their part! I am sure if I had any crazy ideas they will overrule me or refuse to put their stamp down🙂 It's a tricky balance between costs and space usage, with gravity getting in the way. If only I had more funds to fight gravity!
A packaging engineer I worked with had a favorite saying when working with case conveyors: “Gravity - not just a good idea, it’s the Law!”
Cladding each side of the roof joists either 5/8” or 3/4” plywood, glued and screwed usually adds significant load capacity, at least it did for my roof and floor systems that I recently built.
Adding locations to attach a crane track of done kind or suspending rods is future proofing your shop.
After all the planning I did for my shop/garage I still find I had not installed enough solid blocking between wood wall studs for all brackets, shelf’s and cabinets I want to hang. I wish I had fitted 5/8” plywood between studs from 36” above the floor to 7’.
I specified this for many new school projects over the years but failed to do it in my own build.
I am now fastening g 3/4” plywood over top of finished drywall.
