Oh oh. Green tractors. I live in red tractor land.So here are a few shots of my shop.
The tractors belong inside, but the wedding this past fall screwed that up. No room inside right now.
I didn't take photos of the tractor parking areas. They are just boxes and stacks of stuff put there temporarily.
I thought I'd start the inside tour with a shot of my electronics work area up on the mezzanine. I used to think I had a lot of electronics equipment, but after seeing @slow-poke's, I think my stuff is pretty bland. I can't turn stuff on like he did either.
My soldering station is on the left. On the right are work surfaces made from inexpensive plywood and/or 2x12s on boxes. I have several projects on the go there now. There is also other stuff on a storage rack. I normally have my drafting board where I am standing to take the photo, but I had to move it out of the way or I couldn't get a good photo.
Above is my metal shop working area. The lathe is on the right. To the left of it and behind my mill is a long rolling cabinet for lathe tooling. It is easy to just turn around to work on the lathe or to work on the bench.
My mill is beside the lathe bench and it faces another work bench on the right for my big vise, grinder, and drill press. My surface grinder is back to back with the mill.
It's easy to work in the area because you don't have to walk far and there is always a workspace available just by turning around or walking a few feet between machines.
Last, but not least, above is my break room. Before you get all jealous, keep in mind that this isn't normal at all. Usually, it's packed jamb full with in-process projects on the counters and tables, 11 big planter units, seed bags, reference books, farm chemical storage, and repair parts. But I had to clean that all out for the wedding. In fact, it's so clean and tidy in there right now that it's actually downright embarrassing. To be honest, I'm ashamed of it. Sorry about that......
There's one other problem, with so much steel and iron concentrated so close together, it's creating a gravity well and warping time and space.@Mcgyver - the only problem I see in your shop is that there are only 3 tires on the top shelf. Its driving my OCD crazy.... 2 or 4 not 3 unless you tell me you have a 3 wheeler.
I like the little cylindrical grinder you got, do you use it much?Miniature JS cylindrical grinder
I can always anchor bolt stuff like that into the walls and haven't really had to much issue with that. Can usually push crap in with equipment and round stock. But I could weld lifting lugs on I beams if the need arises.Anchor points for winching in the heavy stuff.
Front, back and both sides and with a couple of snatch blocks you can move stuff anywhere with little fear of tipping.
Insulation.I like the little cylindrical grinder you got, do you use it much?
My shop is a work in progress ATM. So it's pretty clean ATM. Don't have current photo when I get home from pre Christmas activities I'll shoot some pictures of my garage and up to date photo of shop. 41'x61' so I could have true 40x60 shop lol. Also max span before I had to use commercial trusses.
I got a deal on some 22" I beams so I cut them in half and gonna give them a forever home in the floor of shop so I can weld stuff to floor. I got 2 beams in every bay.
I would love to install gantry crane in shop but probably gonna just build Jib crane for forklift.
Any suggestions I can add to floor that maybe handy let me know I pour concrete on Jan 30th. So some time for last minute additions 🙂
Like your start.I like the little cylindrical grinder you got, do you use it much?
Rebar is already tied and beams leveled lol so no foam and foam is about 8k ish for high density foam 2". I did think about it but the municipality I'm in requires additional stuff to have it. When I built the house I lucked out on bunch of 4" roofing foam for cheap.Like your start.
What are you doing for electric?
I know what the light switch is for in the first two photos and the vise in the last one !!!Full set of show your shop...
The last two are especially for Susquatch, becuase everyone needs a little chaos, with a sprinkle of swarf on the mill table for good measure!
View attachment 56381View attachment 56380View attachment 56384View attachment 56382View attachment 56386View attachment 56387View attachment 56388View attachment 56389View attachment 56385View attachment 56379View attachment 56378View attachment 56383
@phaxtris you probably mentioned already elsewhere, but what is the (presumably) homebuilt project?
Fire extinguisher, eye wash station, first aid kit, carbon monoxide detector, increased air exchange when needed (I have a 2 speed exhaust fan), somebody who cares enough to come looking incase you don't come in for supper...
Heh, I just finished a rebuild of a Zenith front strut & wheel. Its a cool aircraft!I dont have a thread on it anywhere yet.
Its a zenith 601hd i bought out of spring bank about a year and a half ago, i just started really working on it since the prop hub was completed. It has a long way to go, there are no records of the pre-cover inspection with the appropriate people. I have obviously drilled out the center spar section for inspection, i still have yet to do the wings, that is going to be a summer thing......wings obviously take up a lot of space so i will probably do it outside, so as a result im working on the gear, fwf, all the other things i can plug away on while its cold
Ill make a thread up here in active projects soon.
I also think more people should do advanced first aid courses as the amount of people don't who dont know how to stop arterial bleeding or lesser bleeding is shockling high
Where do i find clean blue shop towels? In my shop, even ones coming off the roll have big greasy fingerprints on them. 😀A couple blue shop towels (clean preferably),
