Like any design problem, 'it depends'....
I used to do a lot of home renovations between software contracts - to clear my head mostly. I got to see the negative side of PEX1 and PEX II. Had to replace them with copper. (I don't do PEX - to do it right you have to be an expert IMO)
I've installed new copper into houses with 80 year old copper, and things are still working fine. Some calcium buildup in the old pipes, mind you, and the old stuff is ever so slightly different size, but is easy to work around.
I think you can get away with PEX, if you use the high quality connectors, and only join using junction blocks. Less costly than copper, but more costly than a bare-bones PEX install. If you buy shrouding to prevent UV exposure, you are driving towards copper price quickly...
tough call. Depends on what you can afford.
