trlvn
I'm embarrassed to say this, but some itty bitty set screws are kicking my butt!
I want to replace the gib screws on my tiny Atlas 618 lathe. They use a slotted drive and I broke one the other day. I figured I'd replace the screws on the compound (4 X 8-32 by 1/2") and the cross slide (3 X 10-32 by 5/8"). These are "dog-point" screws where the dog engage in a little depression in the gib so it doesn't get left behind. I want to switch to hex drive screws. In the following picture, the original parts are above the ruler and the new cup point screws are below.
But BoltsPlus did not have any dog point screws in stock and I'd have to order a box of 100 of each size ($12 X 2). I thought I'd buy cup-point screws and then use the lathe to form the dog point. I tried to use my HSS parting tool to cut the dog point and promptly ruined the edge. I've never really used them, but I do have a few braised carbide bits that the previous owner sharpened. I selected the best looking one and got a little better cut but the tool pressure pushed the part back into the chuck. I had wrapped the screw in a piece cut from an aluminum can to try to protect the threads from the chuck jaws.
These screws must have been hardened and tempered, right? I don't think I want to anneal them, do the work and then re-harden/temper.
If I had a tool post grinder, I think that would be the easy solution. Alas. Perhaps I could freehand it with my Dremel? Not crazy about this because I'd have to be so close to the chuck.
I've wondered about chucking them in a drill and freehanding against the bench grinder or 1" belt sander?
Any suggestions before I try something that turns out badly?
