CA-AB Sched 40 Aluminium Pipe
Alberta
Type
Supplies
Yea that was the one, I couldn't remember if it was a challenger or a Chinook
And yes I think the Chinook with floats on it with any of the common engine choices would be scarily underpowered. There are a few Chinooks with Rotax 912 on them however and I imagine that changes the possibilities quite a bit.
I like this idea however I am concerned that all the force/pressure of the tail wheel mount will be in one linear place of fuselage tube, where as other mounts distribute the load over four linear locations. I am not sure tho that matters?......
Could make two mounts, one fore, one aft.
Maybe make it a continuous mount? Make the inside part conform to the ID and the outer conform to the OD and sandwich the wall of the tube between them. That would involve a fair amount of machining of fair sized blocks of aluminum though unless the pieces could be rolled from sheet/plate.
Another idea, make a couple of clamps that fit over the “tail-cone” tube and bolt the spring mount channel to the clamps. The clamps could be two pieces each or maybe blocks with a saw split to allow them to open enough to go over the tube.
D 😎
In the text description a few posts before the CAD work I suggested 3 mounts for 8 inches. With 2" "washers" inside a 4" tube I figured that should be stiff enough. It would be interesting to know the weight on the tail wheel but I doubt it would be more than 40 lbs. 40 x 6 ( g load) x 3 ( safety factor) = 720. Couch engineering says go flying.
PS no real engineers were consulted in the design of this tail wheel mount.
Yes your design may very well be adequate. My tail wheel weight is actually very heavy 106 lbs with plane unloaded however that can vary depending on plane loading.
One other design I am contemplating that I haven't yet discussed which @Tecnico suggestion is similar to, is using clamps (as in hose clamps) over the outside of the tube to hold the spring mount on. One consideration for this style of mount is that I would have to cut through the planes' fabric for the clamps as the position where the mount would be is fabric covered. Once I cut through the fabric the "damage" is forever done. I guess maybe that's what duct tape is for!
Wow, was my first thought but looking back at the picture that of course makes sense with the pusher. Is it tandem seating ? So I'd guess single occupant and low fuel would put the lightest load on the tw. It'd be interesting to see some tw weights in various configurations.
Yes it is tandem seating. Yes with me sitting at the other end of the stick would make the tail wheel considerably lighter. Having a second occupant probably adds more tail wheel weight? I haven't flown the thing yet with only one aboard yet.
