CA-AB Sched 40 Aluminium Pipe
Alberta
Type
Supplies
Rats. Thanks for looking tho.
Just a thought…….
After you weld the 6061-T6 it will lose it’s temper/yield strength so that might point you toward where you could acquire something more readily formed like some 5052 plate which is common in H32 temper and weldable.
You would have to check the eventual (theoretical) yield strength of the 5052 once welded to see if it’s enough for your purpose.
From flat you could form it to the shape you need and go ahead and weld the channel to it to get the bracket you want.
D 😎
