rotary table and the number of slots
Hruul
Lee - metalworking novice
I am looking into getting a rotary table, and noticed that some have three slots at 60 120deg. and some have four slots at 90deg. Is there a good reason to select one over the other or does it really depend on what you are planning to mount to the table that makes one better over the other?
Thanks in advance.
Lee
The number of T-slots is usually proportional to the table size. If you have the choice for a given table size, get more slots for the reasons others gave above. But I wouldn't let fewer T slots stop me from taking advantage of a good buy. You can always make it work.
Most 6" rotabs have three slots for reasons such as Susquatch mentions, four slots will be common in 8" and up. I prefer my 8" with the four slots due to the type of work I use it for combined with the specialized fixtures I make to go on it.
Interesting centring fixture!
I too have been pondering the 4 vs. 3 question so it’s a timely topic. I had come to the decision that 4 was better for more flexibility of fixturing things.
D :cool:
A very interesting set up @1018Machine. Can we ask what type of work are you doing? Or is it," you can ask, but if I tell you, then--"
For centering, perhaps a 4 slot might be easier to get work centered then a 3 slot.
Can we get a better look at how you did your quill DRO Scale?
I'll snap a pic of it when I head out to the shop. It's a four axis model from DRO PROS, I used Z as the quill and U for the knee.
OK, looking forward to see how you did the quill. Looks quite different from what I did.
I did the Z & U thing too. Then I added them together for a total Z. I love it!
As others have said, it depends. I have a 4 slot, it is a pain in the butt (it came to me as a bundle purchase, set up and works well - once the chuck is centered, but getting it on center is the chore).
Plan before you buy. Like Susq says, you can make anything work. If a chuck is going to be the primary resident on that rotab, then you should identify the chuck and how to mount it when you buy the rotab.
For a rotab, it is nice to have a front mount chuck (makes centering easier, you don’t need an adapter plate, you can use a chuck the same size as the rotab table) - the 3 bolt front mount is very common for 3J & 4J scroll chucks. Obviously there are options (see comments above) - make/buy a mounting plate, drill more holes in the chuck body, source a front mount chuck with 4 mounting holes, etc.
If you are purchasing new, then you have choice. Let us know how you make out.
As promised, here's my mounting idea! Nothing fancy just some 1018 plain carbon steel machined to fit the application.
Sorry for the hijack @Hruul.....
Go figure!
That said, 6in is still tiny.
Not on a Mini-Mill: the Sherline 4” plus 5” plate is perfect. I have a somewhat lengthy post for my “Happening” thread showing the various accessories for my Sherline (my shoulder threw a wrench in completing it), but I should have it posted soon-ish.
In your first photo, it wasn't obvious how you did it, but the photos you just provided show it is very similar to mine.
You can see my whole install here:
As you spend more time here, you will come to know that hijacked threads are a part of the culture on this forum.
No apologies needed.
