Rockwell drill press with Reeves drive
slow-poke
One of these is available locally. Kinda cool. If I get it I would swap is a new motor and VFD for wider range.
Looking for comments good or bad from anyone that has used one.
Might be on the small side for my liking.
I don't know about Reeve's drives on drill presses but they are generally detested on wood lathes.
Reeve drives is what is on a variable speed milling machine.
I've worked on lots early in my career. They can be finicky, but generally very simple. On Bridgeport style mills (and this drill should be along the same basis) there are 2 variable pulleys, one spring loaded, the other by chain which will open and close the pulleys alternatively. The upper pulley half on each pulley should have nylon bushings and steel keys that slide up and down. Those were generally the biggest issue, but are cheap and easy to make. Servicing them can be a pain if you ever had to do bearings or a belt change. (Again, bearings are reasonbly cheap) The hardest part is the belt, you have to ensure the chain side pulley is wide open before tearing it apart to allow easy removal and install of the belt, otherwise you are fighting the spring pulley as it will always naturally close tight, meaning if you have both pulleys closed tight, the belt will never come off or go on. Now again, a bridgeport has Hi/Lo and a few other gadgets in there, this drill should be significantly simpler and lighter duty aka cheaper parts.
I wouldn't hesitate buying one that had a reeve drive.
Fwiw, Schaublin used a Reeves drive on some of their lathes and mills. If good enough for a Swiss person, sure is good enough for an amateur like me.
Only thing I’d be cautious about is overspending a Reeves drive if like you mentioned you’ll add a vfd. Guessing you’re more interested in lower speed?
Another issue with reeves drives, and of which is operator error, is trying to adjust speeds without having the machine running at full speed yet. I've seen people snap pins or bend stuff trying to crank the handwheel with the machine stopped or just getting up to speed.
That, and worn bushings/keys or belt seemed to be the biggest concerns with them.
