Chipper5783
I've never tried it, but you have me interested. I just assuming it would chatter to heck. I do have some old imperial hubs from PA in a box in the shop. I'll see if I can find them. I don't think they are hardened. I do have boring bars that should do the trick. Any other tips?
I assume you have this sorted now? Like Kylemp - an interrupted cut in a lathe is not a big deal, whether boring, facing, external - whatever. Obviously take it a bit slower and make about 3 equal spring passes at the end (with a tool you know is sharp). For an 11/16" hole and if you are actually going to target a slip fit then the tolerance won't give you much to play with (as Kitta above points out). Pull up a Limits & Fits chart (SKF has a good one, also Machinery's Handbook) and they spell it out very well.
