I'll throw in my nickel here (no pennies so can't do '2 cents worth' anymore). I go for Maximum brand at CT whenever given the choice. The hoist on sale looks sweet. Princess Auto is (IMO) equivalent to CT's Mastercraft - OK but not great - but I do often shop at both CT & PA. PA is where I got my 10t pot-a-power which works just fine & was a bargain price on sale.
@Hruul - If storage footprint is a big issue - what about making (cut & weld modification) the rear wheels slide in & out. That could add stability by making them slide out a few inches wider than the original configuration and also narrower it up when going through a doorway or when in storage.
As an aside (and why this thread caught my eye) I have been considering making an engine hoist similar to the one in
@David_R8 's pic.
I would use the surplus 4" aluminum channel that I have, plus the port-a-power from my 10t press. Now (thanks to Lee's concern) I'll include making it more compact with adjustable width rear wheels (or maybe make the rear wheels on a removable beam that only comes off when in storage - I don't have to go through any narrow doorways.)
FYI - here are a few pics of my press and the Al channel. Also note: cutting the aluminum to size is accomplished by using both my table saw and miter saw with a 7 1/4" carbide blade for aluminum. Slow & easy + lots of WD40. The smaller blade reduces the tip speed by about 28%. The kerf is also thinner.
