We had interesting failures in these lamps although Vancouver is wetter than Calgary.
Some of the lamps that weren't well sealed would pump in moisture in the way described.
Here you can see some lamps are warmer than others. The temperature display would show red when they reached 60C which they did one July summer day.
During the day the lamps would heat up from the sun. We had a temperature sensor in each lamp and could actually map out and see the change as the day warmed and then cooled. Switching on the lamps at dusk and off after midnight exacerbated the issue because the now lower pressure inside the lamp resulted in cool moist air being drawn in. Over time this pumping action along with occasional rain resulted in some lamps filling up with water. Literally we had a water line on some lamps halfway up the lens. Needless to say those lamps were destroyed.I was wondering if having the AMS placed on top of the printer was maybe causing some of the issues. When the printer is on the AMS gets hot and would tend to cause the air inside to be "expelled". On cool down fresh air would be drawn into the unit.
I'm in Calgary and it's not really the most humid place in the country.
