It’s a 12v systemSounds odd to connect to two batteries unless they are in parallel. Most inverters are 12V not 24V. Not sure what you have there.
The cable size called for is bigger than you are using, but either way, a 2 or 4 cable suggests 12V not 24. Typically lower voltages require bigger cable. I know that isn't intuitive. Just trust me on that one.
What does it call for and what are you feeding it?
Regardless, back to the cable for a second. Big cables need GREAT connections. A poor or small connection will cut the cables capacity out from under it. Cable Clamps don't generally cut it. Needs to be a regular battery clamp bolted onto the battery terminal. Not always easy to do for secondary loads. But you can get battery clamps that will connect two high current loads at once. That's probably what you need here.
The draw too high suggests a short circuit or a load not designed for an inverter - eg a 120V device on a 240v circuit.
Also possible the load doesn't like a square wave power source or something like that.
Do you have a decent multimeter? If you have a good one, you can measure the voltage drop across one of the cables to calculate actual input and output current and voltage. Don't try to use the meter in current mode unless you have a current loop for it - you will fry it.
At any rate, my very first check after looking at wires and connections would be to do voltage and current checks on everything.
The theory on hooking to two different batteries is that you aren’t “pulling” through one battery. The way it was explained to me was, if you have (more so starting the motor) both positive and negative on the same battery, that one battery does more of the “work”, and over time it will be weaker than the rest.
These are a 3/8” NC post style battery, generally the cable ends are soldered or crimped on the cable, then a 3/8” nut secures it to the battery post
