I'm really struggling in just brazing heavy brass. It's said that the process is just the same as soldering with a torch. I tried using flux paste, as well as flux coated bronze brazing rods; and it's easy enough to bind the solder as that is all that melts; but unlike silver soldering it does not bind to the base material even when it is very clean without managing to melt the surface of the base material and fuse it with the pool of solder. If you ask me that is more like welding, but brazing and soldering should still hold without fusing the metal.
