friend of mine sent me that, I asked him where his gantry crane was, one of the reasons I dislike engine cranes
I wonder if they will give you a raincheck so you can get it for the sale price if they don't restock before the sale is over.
We were able to get a raincheck on one from the south edmonoon store.
Fantastic John you won't regret owning a gantry, keep us posted when you set it up.
I designed and built this gantry for the Vintage Aircraft Restorers group at the WDM museum so we could install wing sections, engines, and hang props. Yes the correct term is you hang a prop! Uprights are 2 inches square 1/4 inch thick tubing and according to my professional welder the cross beam would carry 3000 plus pounds. Chain hoist is a 1 ton and the beam slide has a brake installed.
Too tall for my garage so I donated it to the museum.
This is an old post, but I figured I ask. I am looking at the PA gantries (1-ton and 2-ton) and I have two question that some of you guys may be able to answer:@gharakh You might need to make an adapter plate per wheel. Making your own brake shouldn't bee too hard.
Thank you for the clear response and explanation. I fully understand the issues involved. I am going to wait for the 2-ton PA crane and will pick one up when it is available. When I first got my machines, I built a crane out of wood. It handled all of them well, but the pucker factor was too much for me to repeat. Since then, I had used up the wood for other projects.My friend has the one ton version and I bought the 2 ton. All the parts on the 2 ton are made from larger dimension and thicker wall steel but the actual footprint of both is the same. The 2 ton crane lifted my 3500 lb mill with no drama and was very stable doing it. I think the warning about moving the crane while it's loaded is to make them idiot resistant. If you have a heavy machine suspended from any crane you want to be very careful if you try to move the base so you don't get the load swinging, the momentum of a heavy swinging weight could easily topple the crane or buckle the structure. If you try to move a loaded crane on an uneven surface you could exceed the design limits of the vertical structure by adding side and twisting loads. If you are working on a very smooth concrete floor that has been swept clean and you keep the load very close to the floor I think the crane could be moved if the pushing force is applied gradually and near the bottom of the crane. I moved my mill about a foot while it was suspended with no problem but it did create a pucker factor. I read a post on another forum where a guy lifted his brand new mill on his glass smooth floor with his brand new 2 ton gantry crane. The floor in his shop has a slope near one wall and he forgot to lock the wheels, the crane and machine rolled down the slope and crashed into the wall. No harm done other than some holes in the drywall but his post reminded me how things you don't think about can cause disaster. Luckily nobody was standing in the path of that out of control machine. I shortened the uprights on my 2 ton crane by 6 inches so it will roll through my 8 foot garage door when fully lowered.
Thank you for the response and the recommendation. The 1-ton should handle 2000 lbs and the 2-ton, 4000 lbs. Are your numbers of 750 and 2000 lbs just being cautious and conservative?@salahz I think that our members have found the PA crane to be very good for the money. It is a little picky to set up, so it is more difficult to take down and erect for remote applications - this also implies that it will be stored fully built.
@John Conroy and I have talked a bit about his and I'm intrigued to hear his take on this.
I took a different approach. I built a *heavy* gantry crane about 10 years ago. I designed it to be erecrted on site when needed, and stored in pieces. It cost around the same as buying the PA crane, at the time. Given steel prices I doubt I could get the steel for double that price now. The main reason I built one is to move it under load, which required a stronger structure.
I made it far too heavy for the purpose, so I need help in erecting it. The PA crane doesn't have this problem.
This is just my take on it -- I think the '1 ton' is good to 750 lbs lift, and the '2 ton' can probably handle 2000 lbs. In lifting things always take the safest approach possible.
