Nut on dead center
What is the purpose of having a threaded nut on an MT dead center? Tool extraction maybe?
I suppose you could use it to pull the mt free of the female socket if it was jammed in ? Thats my guess
I have a center like that with threads.
nut deals with extraction.
lathe tailstocks lack a through hole to aid in knocking the dead center out of the tailstock. Tailstock pressures in dead center turning applications are also considerably higher than that normally used in grinding. The lack of a through hole coupled with the high tailstock pressure can literally lock the center into the tailstock making it very hard to remove. CNC dead centers are threaded to allow the use of a take off nut to help remove the center from the tailstock. The nut bottoms against the face of the tailstock as it is threaded over the center. Since the nut can’t move axially, forcing the nut to turn with a wrench draws the center out of the tailstock.
I’ve always seen them described as CNC dead centers.
I do think it would be handy for a headstock dead center since it saves having to awkwardly tap on a bar through the spindle to get it out while trying not to let it fall onto something.
If I could find one in MT5 at a reasonable price I’d get it for that purpose.
About $50 will get an offshore from many suppliers. Add a grand if you want a Royal. Threaded aren't as common on KBC which is why I was asking. Just so happened to be looking on Ebay which is where my pics came from. I'm pretty sure I could tap mine out through the headstock spindle tube. I'll have to check if the thread would play nice with the face plate or dog drive plate. Right now I use an MT3 with an MT5/MT3 sleeve which came with the lathe.
When I bought my South Bend Heavy 10L it did not come with a dead centre. I learned from the South Bend group that the taper of the headstock was non-standard. Or you could say it was standard South Bend Heavy 10L.
Anyway, from one of the group members, I bought an adapter to MT-3.
My only complaint about it is that the MT-3 extends out too far. Would have been nice if the internal MT-3 taper had been larger. I'm not sure this part is hardened and although I turn between centres a fair bit I've not been bothered to try and fix it or create a new adapter.
I’m using a mt3 in a sleeve right now. I think if I’m going to bother getting a mt5 (slightly better runout hopefully) I’d get one with threads. The threaded ones tend to cost more.
There’s nothing stopping me from tapping it out through the headstock, I’d just prefer to use a nut.
S
I don't know your lathe (and actually I have to go back & check my own) but wondering out loud here. It might appear to stick out too far with no other accessory mounted to on the spindle. But once you mount a drive plate or face plate in order to drive the dog, it could be that the dead center would also have to protrude more in order to engage the work? My lathe is D1-4 so I'm not quite sure what I'm looking at on your 10L picture.
S
I'm usually so wordy. But this time I think the picture is worth 1000 words.
I use a home made drive. Should really make the pin thicker.
I’d just make a sleeve to slide over the dog.
In essence that's what I did by making a dog with a longer arm. But I think in reality the idea of a shorter dead center is the best idea. I found the long shaft I used for turning the pulleys really flexed too much.
