I’m using a mt3 in a sleeve right now. I think if I’m going to bother getting a mt5 (slightly better runout hopefully) I’d get one with threads. The threaded ones tend to cost more.About $50 will get an offshore from many suppliers. Add a grand if you want a Royal. Threaded aren't as common on KBC which is why I was asking. Just so happened to be looking on Ebay which is where my pics came from. I'm pretty sure I could tap mine out through the headstock spindle tube. I'll have to check if the thread would play nice with the face plate or dog drive plate. Right now I use an MT3 with an MT5/MT3 sleeve which came with the lathe.
Results Page 1 :: KBC Tools & Machinery
www.kbctools.ca
I don't know your lathe (and actually I have to go back & check my own) but wondering out loud here. It might appear to stick out too far with no other accessory mounted to on the spindle. But once you mount a drive plate or face plate in order to drive the dog, it could be that the dead center would also have to protrude more in order to engage the work? My lathe is D1-4 so I'm not quite sure what I'm looking at on your 10L picture.My only complaint about it is that the MT-3 extends out too far.
I'm usually so wordy. But this time I think the picture is worth 1000 words.S
It's already on my list. Project #42.You appear to have a taper attachment. Just make a couple of stubby dead centers. That's what I did.
In essence that's what I did by making a dog with a longer arm. But I think in reality the idea of a shorter dead center is the best idea. I found the long shaft I used for turning the pulleys really flexed too much.I’d just make a sleeve to slide over the dog.
