Well not quite....you'll be able to cut any gear within that module what your cutter set cuts. There are so many different modules, DP's, and pressure angles it would get very expensive to own a set to cut every gear. But you probably meant you'll be able to cut any gear you need for your own particular lathe.I did order an inexpensive set of gear cutters though. I'll soon be able to make any gear I want.
