[mention]Janger [/mention] have you figured out a price yet? [emoji3]
Another thing you might consider is the clamp faces being flat like most clamps I think it would be useful to have a v cut in opposite the main gripping flat that way they could be rotated to hold round to flat or round to round without skating they could have a spring and ball locating the position keeping them in place. I would cut the v on both but at 90* to each other for 2 directions of holding.
And that is probably why they were discontinued you could probably move the rod to the left of it like the can’t twist because the more you get to the pivot the less clamping force.The only other thing I'd suggest is how to size a graduated set, like small / medium / large for example. Looks like the width is about 2X the distance between pads & jack screw. So big clamps may not be appropriate for small jobs given the overhang. And when they are wide open you lose a bit of mechanical advantage. Some things may scale, other things (like fasteners, therefore threaded holes, jack screw... maybe even plate thickness) may be different for different sizes. I'm a 1-IKEA wrench kinda guy, but sometimes that's just not possible.
I got busy and designed up a version of the dimide in Fusion 360. This is about a 6" throat depth version.
I've been mulling over options on how the threaded rod would exert the clamping pressure. The area in red circle is still to be defined. I was thinking of using two locking collars on the threaded shaft - one on each side of the stand off - probably with flats or even holes going right through the threaded rod for a pin. Any suggestions on this? I see on the starett 164 there are two square blocks on the shaft. The one located on the threaded section is clearly threaded and moves back and forth exerting the clamp pressure. The closer one at the handle end though is not so clear what it is doing. It seems it must be fixed in place yet also allow the shaft to spin - @eotrfish how does that part work? Perhaps the knurled handle part presses on the square block and the rod simply spins inside the block? Is the threaded rod and handle all one piece? and thanks for posting that disassembled picture it's interesting.
Does the far end of the threaded section have a screw on stop?
I also like the standoffs are internally threaded and use machine screws for assembly. And the bend in the arms means you only need one length of standoffs and only one clamp pad depth - very clever Starett. (Edit -> well not quite looks like there are a few different lengths of standoffs) And I see the standoffs holding the clamp pads have a different head diameter - I wonder why they did that?
Kevin[mention]Janger [/mention] have you figured out a price yet? [emoji3]
John
Regarding the threaded standoffs - it is a great idea, and the guy in Winnipeg uses that for his design. It is more fussy however and would take lots longer than peening the ends. Regarding peening, I wonder if your fantastic Fusion 360 designs could easily be modified to show a longer end on the 8 standoff pins? Or, alternately, leave
JohnBrian
How far above the surface should the standoffs stick out for peening?
J
This summer I have been designing and building my own version of Kant-Twist clamps in 3 sizes - 2.5", 4.5" and 6". I have the 6" one finished and will include pictures. I am happy with the design and have learned a lot from the process of building my first clamp. I had a decent quantity of the various arms manufactured locally, using a laser cutter, and this has worked well. Of special note is that the design includes all necessary holes - very precisely located to make the clamp go together accurately and work smoothly. I created a document with many more details and will attach that for anyone who wants to read the fuller story. This documents covers the flaws in the clamps I purchased, the major design goals of my re-design, the process of making the first clamp and some prices.
Happy to make available sets of the arms to anyone interested - details in the document attached. My thinking is that only a few of you would want to read 5 pages of details on this subject! But, for anyone interested, the complete story - so far - is in the attached PDF file.
JohnBrian - how did you do the fancy ones finish?
Everybody - if I made the standoffs from aluminum would there be any strength concerns? It would be easier to thread…
I think that aluminum would work very well if, like John you intend to drill and tap the standoff ends for small bolts to hold things together, and not use peening like I did. I think aluminum might be too soft for peening and so I did not even think of that. I now am thinking that brass might be better than aluminum? Very easy to machine, drill and thread. For the record, I have made the central pivot for my second and fancy clamp from brass. There will be pressure on this pivot point, but the diameters are large enough so it should not be a problem. We shall see...aluminum would be fine. the standoffs don't get that much stress...
Kevin - Prices are included in the .pdf document I posted initially. Hope that helps.[mention]Janger [/mention] have you figured out a price yet? [emoji3]
