Emery
Hello Everyone,
I just picked up my first metal lathe which is a Standard Modern 9 Utilathe Model A.
I am very happy with it so far and everything seems to work as intended!!
I am brand new to the machining world but have experience in fabricating (welding mostly, Stick, Mig, Tig) and mechanics!
Right now I am giving my new lathe a good once over clean and will going to do head stock oil change / flush here shortly. What else would you guys recommend checking/cleaning while I am at it? This was literally and “barn find”.
I am also diving into the world of feeds and speeds for HSS and Carbide Insert tooling....wow there is a lot to learn =) (Any cheat sheets out there?) I’m sure it will be second nature shortly.
Also, where does everyone buy their metal stock from in Edmonton? - metal super market....?
Does anyone have the same model as me?!
I chose 30w compressor non detergent crank case gear oil. (Closest thing I could find to the recommended “SAE 30”)
Thanks for reading!
Thanks for reading!
