https://www.ebay.ca/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=disc+cutter&_sacat=0
If you just want the dang tool...
I know you said disc cutter is bit different that what your are targeting, but just to show an example of material makeup.
The tool's holes have been machined and honed to make fine, clean cuts. The punches are oil-quenched tool steel that have been drawn for hardness and durability. The base is case-hardened and ground.
https://www.ebay.ca/itm/Disc-Cutter...h=item463558d567:g:f3IAAOSwPhdU7Rva:rk:7:pf:0
This post certainly peaked my interest. I recently started searching for O1 tool steel (3/16"x 1 1/2"x 48"). There is nothing available locally here. I did discover a link to a company called "Metal Supermarket". They do show a location in Calgary and a couple in Edmonton. Has anyone had any experience with them? I emailed a request and got a quote the same day, but, since its about 5 hours away from me I don't want to make the trip without a little information.
Attempting to clone this, so I need tool steel as follows
Two 5" X 4" X 1/2" plates (could go smaller)
Two 1" dia X 4" long round stock
Any one?
I used their online quote option because I ran into the same issue as you did. Since I have had such problems sourcing specific steel in Saskatoon I wasn't sure if what I wanted was even available. I am using it for knifemaking, so I was looking for 3/16 x 1 1/2" flat O1 tool steelI have had mixed good and not so good experiences at MSS. Did you use the online quote option or email them directly? The online quote option would only list drill rod for me. So, what did they quote you?
Thanks for the info. I will look right away. I am curious because the 3' piece I was looking at purchasing was going to hit the $100 mark plus the cost of going to Edmonton.BrianH, real simple.
A) get a MSM quote for a given size of O1. Add 5 hrs of gas & your time
B) compare to KBC published prices. Add 8.95 shipping to your door. You will probably have it in under a week.
https://www.kbctools.ca/products/TOOLROOM ACCESSORIES/STOCK MATERIAL/DRILL ROD/1644.aspx
fine print: 25$ min order for flat rate shipping, but there might be something else of interest including Black Friday discounts
https://www.kbctools.ca/content.aspx?file=customerpages/terms.htm
Let us know what you find out. It would be a strange day indeed if MSM came out cheaper.
