Called back-shielding, or back-purging. It was suggested earlier in the thread. Won't call it a waste of time and money, but for a mild steel exhaust system, pretty close to that! If the fit is good, and the weld is progressing nicely, there will be very little internal protrusion of the bead.Not sure what I’m talking about here or what the process is called, maybe an experienced welder could help, please chime in- but I recall a ‘weld.com’ or maybe a ‘tipandtricks’ youtube when both sides of the piece are exposed (protected) by the same shielding gas. In your case: the inside of the exhaust pipe would be filled with the same shielding gas as the flow from your torch (MIG or TIG).
That is a good technique for repairing holes on thin material. The metal added to the bead adds more heat resistance every time, and the bead is something to point the arc towards to withstand the heat. Adding metal to the bead works to cool the weld. If you have a foot pedal you can also use that to control the heat. I like tig welding the most because of how much control it gives you over the heat and feed rate.Pulse, move a bit, pulse, move a bit. Slow and steady.
YES it does. But I have never really used it.Does your tig welder have pulse capabilities? I really liked using pulse on my bicycle tubing, although that was ~0.035" wall thickness.
I'd second using mig wire as filler. Rule of thumb is for the filler to be no thicker than what you are welding, but I don't know if 0.020" mig wire is readily available?
For the moment I have been trying OA. I get SOME good results, but getting the same heat each time I start the torch is my current challenge. I'm using a zero TIp and turning up the A to get just out of the smoke zone then adding O. The just out of smoke zone is not always consistent. I see why your friend counted bubbles in the baby food jars. I'll keep working on it.Called back-shielding, or back-purging. It was suggested earlier in the thread. Won't call it a waste of time and money, but for a mild steel exhaust system, pretty close to that! If the fit is good, and the weld is progressing nicely, there will be very little internal protrusion of the bead.
Different gig if the pipe pieces are Stainless, or Titanium. Either will react badly to the exposure of oxygen from the air, to the heat of the weld pool. Some of the outfits that weld Titanium, go to the trouble of welding in a closed box, very similar to a sand blaster, with a totally Argon environment inside.
I disagree with @Janger and @a smile that burning holes is going to be a problem. Applying too many amps, or too much heat, will burn holes. Adjust accordingly! Start low, on practice pieces, work your way up in amperage, until you are moving at a relaxed, comfortable speed. Same with oxy-acet welding. Except that in O/A welding, you have a slightly different reflex to learn, to control the heat that goes in to the work, where you have to learn to twitch the torch flame back away from the weld, to spread that heat out, rather than dialing down the amperage. You also have a fairly "blowy" flame to deal with, which may add to the issue.
Amps = Heat, in TIG, a larger torch tip size = Heat, in O/A welding. In the latter you can cheat a bit, with lower pressures to the torch, but that usually results in more pops and farts too! I have seen O/A torches that used hypodermic needles, as torch tips (some jewellery supply places sell a set), though never attempted to weld with one, and a friend of mine, who was a former Northern Alberta Institute of Technology (NAIT) Instructor, demoed his rig that he made up to fusion weld some VERY small parts, under a microscope, that used, essentially, the finest needles he could get, and a regulator system that used baby food jars full of water, where he counted the bubbles per minute, or the seconds between them, as a way to set his gas flows! Which is to say, if you are blowing holes, you are using too much heat. Period!
But both processes rely on the exact same hand/eye/rhythm coordination. Make a puddle, feed the filler (if needed), move, repeat. Better to take a second for a puddle to form (as you are setting up), than to blow a chunk out of the part, and have to learn how to deal with that (and that CAN be dealt with!).
Speaking of dealing with blowouts... Copper is your friend! The steel weld material, will not stick to copper or copper alloys. Some sections of copper pipe, cut and flattened, and formed to fit inside the blown out area, can be a life-saver! Especially if you have your machine dialed all the way down, and you are trying to build sideways off the edges of the hole you just blew out on the part! If you can form the copper sheet to the inside of the part, you have a tool that will save you a LOT of time in recovery, and prevent leaving a huge scab on the inside of the pipe.
We used a lot of brass bars and blocks, to back up inside corners of quick and dirty fusion welded outside corners of steel drip trays and pans, boxes, etc., when we were making them. Dead easy to bend the box up with a tight inside radius, and whip down the seam really fast with a TIG torch to fuse the seam.
Keep solidly in mind, that it is not that you will not ever screw up a part. It is how you learn from, and recover from that screw-up, that will be how you develop your skills!
Agree with @justin1, above. Get a decently sensitive helmet! I don't agree with his pedal method, really, but if it works for him and his, it works. I prefer to be able to tap the pedal and either start at a very low amperage and work up, or at least, if I want to get the part hot in short time, stomp it down, and back off immediately to a comfortable heat level. As I said before, by being able to manipulate the heat live, you have the options of welding in the third dimension, have seen and done a LOT of pretty neat 'art' projects so done, as well as some very creative ways of bridging very wide gaps, and filling in between free-standing beads.
The more you practice and, really, Play, the more options you will find, when you are not making parts to some engineer's very strictly laid out welding process that you must follow.
Welding, more than many skills, requires a pretty solid grasp of being able to recognize what is going on, and reacting to it in real time. Dead nuts easy, when they spell it all out in an engineered (hopefully competently) Process sheet, but when you do not have fixed settings and fillers, and gaps spec'd out for you in advance, you pretty much have to fall back on experience. It's less of a disaster in the making, if you start at the bottom of the settings, and work up, than if you start at the top, and work down until you are happy with the results!
PULSE - yes!Does your tig welder have pulse capabilities?
Thanks - nice tip. Gonna give it a try.set you heat with the acetylene regulator, crank the torch valve full open, lite it and adjust the regulator to the heat you want.
set you heat with the acetylene regulator, crank the torch valve full open, lite it and adjust the regulator to the heat you want. This way all you need to do is crank open the torch valve full, lite, adjust to neutral flame and you will have the same heat every time, you can do the same thing with the oxygen regulator so that you are adjusting to the same heat neutral flame every time as well.
Do you know of any reputable and economic oxy acetylene regulators with very low pressure ranges? For bicycle brazing I don't think I'll ever need more than 5-6 psi. I set my oxygen regulator for bicycle brazing by just dialing in the valve until I can just see the needle pop off zero lol.
I'm not a hot stuff practitioner yet but I have heard a lot of good things about this MECO torch for specialty applications, using conventional OA regs AFAIK. It apparently has a wide(er?) range of tips & broader fuel valve control. Supposedly favored by guys doing everything between chromoly aircraft tubing structures down to basically jewelry scale stuff.
OTOH, Paul Brodie seems to be using a conventional torch for his bike stuff. He also has some tricks like adding flux to gas? Not sure if this is the vid, he has done a few on his channel.
not sure if this was feedback for me or ducdon, but I think having the highest resolution gauge available for whatever the brazing/welding application would (atleast for the acetylene) make learning a bit easier. Fully opening the acetylene valve at the torch and then setting the flow rate with the regulator to a specific number I think would make it much easier to atleast keep your flame size consistent between torch sessions, no? Is there a safety reason this should not be done?it is pretty easy to be consistent setting the neutral flame, so im unsure that it is worth the trouble. The big heat range adjustment is more with the act pressure used, and you already have a gauge that is acceptable 😉
If it were me, and assuming that your regulator can be set low enough, I'd just go buy a gauge that has the right pressure range for your needs and swap it out for the one you have in there now.
It's either that or buy another regulator set and modify it.
