Haven't received the tool setter yet. Supposed to arrive Jan 4th. I suspect it will be sooner but it's currently in limbo here which is code for it's now on a container on a boat headed your way...You can also rig up a dial indicator and a 123 block to do the same. Feel free to PM if you need detailed help.
Sigh....sorry I have to write this....
OMG OMG no pin, pin broken, what am I to do????? Take it to a machinist to fix it.....W A I T!!! (Insert your won name here) I am a machinist, problem solved.
You guys so funny.
This is exactly what I ordered. https://www.aliexpress.com/item/1005003797600365.htmlDo you have a dial or digital tool setter? The process would be to set the probe against the reference ground surfaces of the setter and then move the quill to and down on to the “plunger” of the setter until it reads zero. The tool setter is obviously zeroed relative to the reference ground surfaces(using a gage or 123 block) The difference between the machine absolute position when the probe triggered vs when the quill reached zero on the setter is the exact height of your probe trigger point relative to the quill(which is your WCS reference for tool heights and probe height in Z)
Yes absolutely that’s a good way to go as well…should get you within 20-40um/.001-.002”. I think a slightly safer approach with this method is to bring the spindle down lower than the block then raise until the block barely slides under it. The tool setter I was referring to for more accurate/repeatable measurement is a manual one, like one of these: https://a.co/d/3dTcuDDThis is exactly what I ordered. https://www.aliexpress.com/item/1005003797600365.html
Looks like it can move 5mm from the 95mm height. At least if 'itinerary' is distance it can move. There's also an N/C overtravel switch which will be wired into the Z axis limit switch circuit.
I can bring the spindle down to a 1-2-3 block until it has friction clearance. Set Z to zero at that point and then move it over and bring it down on the tool sensor until it trips. A bit of math will tell me the height above the table that it will trip and it's supposed to be very repeatable so I can verify that too.
Excellent points, and indeed the MT3 model is about 350 cad cheaper and is in stock vs the R8 which maybe hopefully will be in Canada in Feb. For the 350 I can get a decent starter TTS kit from Tormach including shipping or lots of cheaper Asian replicas to play around with. From what I read on UK and other European based forums, R8 is very rare there and folks over there seem to do just fine without it. I believe the popular Optimum bench top mill which is a bit bigger and heavier than the PM25 clone I’m getting uses MT4. Certainly in the world of VMCs you don’t see any of these older style machine tapers which is why I was lost and confused in making the decision. In any case, I don’t think MT3 is as rare here in Canada or the US especially with Asian imports.To answer original question. R8 exists for a reason - if MT3 was good enough they would use that - BUT R8 was designed for a much larger machine - for BP to work with transfer of power of max 3hp (or maybe 5hp). However, the machine to use MT3 is much smaller than even smallest BP - the MT3 spindles AFAIK are cheaper to make than R8 and thus seller should give small discount. Other than that there is not really that much difference, how much can the MT3 taper stick or move under power in a small mill vs. R8?
Note that if MT taper was "sticking" in the spindle it would not be used in a drill press where all force is down - certainly not in large drill presses with 5hp motors using MT5 - would not want that to stick
Bottom line is R8 is more specialized for milling collet than MT3 BUT for a small mill it may not really matter. I wonder what say Dabbler has to say about this - did anyone do comparison tests that we know of? I mean someone had to.
I wanted a tool sensor to be able to connect into LinuxCNC because I'm using both TTS and R8 tooling. Hence my trials and tribulations with my power draw bar. So I want the ability to place a tool into some kind of R8 holder and move over and determine the length of the tool without some sort of external measuring rig like sold by Tormach.Yes absolutely that’s a good way to go as well…should get you within 20-40um/.001-.002”. I think a slightly safer approach with this method is to bring the spindle down lower than the block then raise until the block barely slides under it. The tool setter I was referring to for more accurate/repeatable measurement is a manual one, like one of these: https://a.co/d/3dTcuDD
Useful for measuring your probe and also verifying that things are working before trusting the tool table…even though i have a couple of cnc routers which are not particularly super accurate, this type of setter really helped me validate my setup before ruining relatively expensive stock materials.
Yes if you measure the tool each time with the tool probe you are getting, knowing the probe height is irrelevant, all you need to determine is the offset between your WCS zero and the top of the sensor. I have this setup as well on one of the routers I use mainly for wood and composites because dimensional accuracy is not as critical.I wanted a tool sensor to be able to connect into LinuxCNC because I'm using both TTS and R8 tooling. Hence my trials and tribulations with my power draw bar. So I want the ability to place a tool into some kind of R8 holder and move over and determine the length of the tool without some sort of external measuring rig like sold by Tormach.
Note that if MT taper was "sticking" in the spindle it would not be used in a drill press where all force is down - certainly not in large drill presses with 5hp motors using MT5 - would not want that to stick![]()
Undid the drawbar a few turns and rapped the drawbar with the end of the ratchet and out it came.
Yup, I don't have a fancy hammer with a socket on it so I just rap it with the butt end of the ratchet handle.You rapped your drawbar with a steel ratchet? I've always been told that was a big no-no. Might also explain why yours doesn't stick. So would oil.
The right tool for the job! LOLYup, I don't have a fancy hammer with a socket on it so I just rap it with the butt end of the ratchet handle.
