terry_g
Today Loomis delivered a Bostar 5C collet chuck. I ordered the one with the D1-4 semi finished adaptor.
The adaptor came with the pins installed, I had to take the screws out and turn them in one turn to get
the eccentrics to lock. I mounted the plate on the spindle and dialled it for runout both radial and axial.
The dial indicator stayed at zero runout. I turned the adaptor until I could just start the chuck on it then
installed it and tightened the screws.
I'm impressed as the taper has about 0.0004" runout. I'm sure I could shim and cut the adaptor to bring
that down but for what I use it for that is adequate. I have a set of collets I bought from Accusize on
Amazon, I haven't checked yet but I doubt they are any more accurate than the chuck.
It was well packaged.
The contents.
No spring on the chuck key.
Ready for use.
The 3/4" drill rod dialled .001"
The contents.
Ready for use.
