Morgan's Pub on 17th
Kris Jensen
Active Member
Just finished the install today here's how it went
Awesome work, Kris!! This is very cool, I bet the customer is thrilled. Did you cut the steel with that protective plastic on? If so how bad were the fumes?
Sent from my B15 using Tapatalk
Actually there were no fumes, the film is designed for laser cutting which gets a lot hotter then plasma plus on the water table I was able to close the garage door and cut with little to none build up of fumes
